79 trans am. Help please
Old Feb 13, 2011 | 06:22 PM
dman0712's Avatar
I have a 79 trans am with a fresh 403 and I deleted most of the accesories and pollution crap. I Need help knowing where all the wiring goes. If possible can someone post some pics? My main concern is wiring to oil pressure sending unit, alternator, and temp switch. It doesnt help that the wires are not dummy proof.
Old Feb 13, 2011 | 09:10 PM
kenny's Avatar
O.K, the oil pressure sending unit is the blue wire, the water temp sending unit is the green. The alt has the plastic plug with the red wire.
Old Feb 14, 2011 | 04:37 AM
cutlassefi's Avatar
Hows it run by the way? Weren't you having oil pressure issues or something?
Old Feb 14, 2011 | 02:18 PM
dman0712's Avatar
Runs fine. theres a vid on youtube under olds 403 firing. Timing is still off and the carb is just something I threw on. Check it out
Old Feb 14, 2011 | 02:20 PM
dman0712's Avatar
Ok so I have some more of the wires hooked up and I got the dash lights and buzzard horn to come on but I cant turn the key to start the car. Steering column seems to be locked. I have a 700r4 transmisson and b&m shifter. I dont have any of the wires to the shifter hooked up yet. Will this cause the steering column to lock?
Old Feb 14, 2011 | 05:09 PM
kenny's Avatar
With the trans swap, have you hooked up the column linkage? IF YOU ARE JUST USING THE SHIFT CABLE, THE COLUMN WILL NOT BE IN THE PARK POSITION THUS NOT ALLOWING THE KEY TO WORK. Sorry, the caps lock was on.....
Old Feb 14, 2011 | 05:32 PM
dman0712's Avatar
ok can you better explain what what the linkage is? It goes from where to where?
Old Feb 14, 2011 | 05:47 PM
dman0712's Avatar
Will the old shifter column linkage attach to the 700r4 bracket?
Old Feb 14, 2011 | 10:11 PM
kenny's Avatar
The linkage runs from the column in the engine compartment next to the firewall down to a hole in the subframe then to the trans. When you use the shifter to put the car in Drive, it spins the column clockwise as you're sitting in the drivers seat. Try this, as you're sitting in the drivers seat, put your hand on the bottom of the column and rotate it counter clockwise. This will simulate the car being in Park and allow the key to work.
Old Feb 15, 2011 | 10:04 PM
dman0712's Avatar
I got the car to turn over. Now im looking for the backdrive linkage. Is it an actual cable or is it all metal? I cant even find any pics online.
Old Feb 22, 2011 | 02:58 PM
blueRAYwhale's Avatar
man, that motor looks cool. yeah you should have that oil pressure sending unit sticking up out of the cast-in timing chain entension housing at the front of the motor(drivers side). you'rs might have that 45 degr. brass nipple on it, put the blue wire on there. the engine water temp.(green wire) connects onto the sending unit that is screwed in the friont of the intake manifold, usually the bottom portion is brass colored. then that heavy red wire which usually has a brown wire running along with it goes into the side of the altenator, then ther's another one with a ring terminal that bolts to the back of the altenator. what about the one that goes to the original carb. solenoid for cars equipped with A/C?
aquabird
Oct 2, 2013 10:34 PM
Flye
Apr 18, 2011 04:24 PM
64Super88
May 15, 2010 07:24 AM
ChrisM
Dec 12, 2008 12:31 PM
drtdobber
Feb 14, 2007 01:16 PM
