Exhaust flow plates?
Old Dec 22, 2010 | 03:30 PM
defiant1's Avatar
Question Exhaust flow plates?
Anyone have any experience with these? I am not a fan of the long tube headers (at least the ones in my price range), so I am looking for anything that can help the flow of my exhaust manifolds. Does this design make sense or this a snake oil type of thing? The following is the excerpt from the dick miller racing website:
http://www.dickmillerracing.com/Engine_page.htm
Exhaust flow plates. These plates will increase the flow on your cast iron production heads by up to 15 CFM by flattening out the floor from the short side radius to the exhaust. The plate bolts between the head and exhaust requiring two exhaust gaskets on each head. Final fitting into the runners will need to be done with hand tools to allow for the closest fit possible in the head being used.
d1
File Type: bmp
Old Dec 22, 2010 | 05:07 PM
cutlassefi's Avatar
If you're not using headers I believe they'd be a waste of money. Scavenging or lack thereof is a big part of the issue, not just flow.
Old Dec 22, 2010 | 05:32 PM
Rickman48's Avatar
Agree with the above - you'd probably get more of an increase with an 'X' pipe on dual exhaust!
Possibly for less money, too.
Old Dec 22, 2010 | 06:46 PM
defiant1's Avatar
Probably right. I had never heard of them used before, so I figured I'd pose the question.
d1
Old Dec 23, 2010 | 07:21 AM
d1
The plates are intended to be a simple way to raise the floor of the Olds exhaust ports to improve flow. Unfortunately, they are a poor compromise at best. They require careful fitting to each port and still are far from perfect. I don't know of any actual flow tests on these plates.
Old Dec 23, 2010 | 10:22 AM
geckonz08's Avatar
I have a set which coincidentally arrived yesterday from the States. I am to using these plates solely because I am worried,if I alternatively weld the floor (to raise it), I may crack the heads.Sure the consensus is that the plates are a poor alternative but hopefully ,if carefully fitted, I will gain a little improvement. Hard facts? I have none.
I am using headers .
mike
Old Dec 23, 2010 | 01:34 PM
geckonz08's Avatar
Fwiw --see pic--about a 0.5 in raise from existing ex port base using the ex plates(this could be altered easily if one so wished
And FYI the plates are very close to 0.045" thick
mike
geckonz08
Oct 2, 2012 04:44 AM
Troys Toy 70
Sep 9, 2012 09:37 PM
Aceshigh
Aug 2, 2009 07:11 PM
agtw31
Jul 12, 2009 09:51 AM
schapman33
Aurora
Dec 8, 2008 07:49 AM
