Stupid Question Needs Answer
Old Feb 8, 2011 | 02:35 PM
mike623's Avatar
The water jacket bolts if that is for sure what they are are located on the sides of the block right? How far in are they supposed to be tightened down? Can you over tighten them and block off a water passage?
Thanks, Mike
Old Feb 8, 2011 | 03:19 PM
Oldsmaniac's Avatar
If you mean the 2 small plugs on each lower side of the block they just need to be tight so they dont leak.
Old Feb 8, 2011 | 03:59 PM
Run to Rund's Avatar
Those "bolts" are 1/4" NPT plugs and have tapered threads. Put sealer on them and tighten moderately.
Old Feb 8, 2011 | 04:30 PM
TripDeuces's Avatar
I used to screw a petcock into one so I could drain the block. Like the brass type they used on old radiators.
Old Feb 9, 2011 | 09:07 AM
Lady72nRob71's Avatar
Just a moderate 'snug' will do it. If they leak, tighten a little more. Being tapered, they seal up easily (even if you forget the sealer)...
Old Feb 10, 2011 | 04:12 PM
tonycpe's Avatar
I use petcocks on the fronts and plugs on the rear .
Much easier to drain since I seem to be changing cams 2 or 3 times a year.
I sure hope I am done with this cam testing this year. It's a lotta work .
I use teflon tape on the threads so I get a good seal without tightening to much.
brown7373
Aug 23, 2015 01:54 PM
auto_editor
Apr 26, 2013 05:19 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
IDAS 69
May 11, 2008 04:53 PM
