Valve covers
Old Dec 12, 2010 | 02:52 PM
Jharken's Avatar
Valve covers
Hey guys, I would like to use stock valve covers with Harland sharp rockers?
Is this possible? I really want the stock look.
Thanks in advance
Jharken
Old Dec 12, 2010 | 03:03 PM
Dave Siltman's Avatar
Yes, I used a thicker gasket and it worked. You might try some grease or vaseline on top of your rockers, install the gasket and valve covers and then turn engine over by hand. If grease appears on the iside of the valve cover you need more clearance. I got the real good thick valve cover gaskets from Dick Miller and am very happy with them.
Old Dec 12, 2010 | 05:14 PM
Jharken's Avatar
Are the baffles removed?
Jharken
Old Dec 12, 2010 | 07:33 PM
dc2x4drvr's Avatar
The baffles will probably have to be removed, and to keep oil from seeping out, I fabbed mini baffles in mine. Thick gaskets help, and to check for clearance just hold the cover on and have a friend turn the motor over, you'll hear a racket if the rockers are too close.
BTW, I run HS rockers.
Old Dec 13, 2010 | 08:24 PM
Jharken's Avatar
Thanks guy's
Old Dec 13, 2010 | 08:34 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I think I have a set of 425 valve covers that don't have baffles floating around here somewhere.
RAMBOW
Mar 20, 2017 06:58 PM
jpc647
Oct 12, 2012 03:11 PM
Ric
Oct 23, 2011 05:32 PM
HWYSTR455
Aug 30, 2006 04:40 AM
derek42
Aug 28, 2006 11:37 AM
