RPM Heads - Alt Bracket
I have installed new RPM heads on my 350. Can someone give me feedback on installing the Alt bracket? It looks like I may have to modify the bracket for it to set flush with the end of the head. I would really appreciate some feedback and any pictures if possible.
I have LH alternator bracket on mine & don't remember any issue w/ install. At most I might have a washer on each bolt BEHIND the bracket to space it out for pulley alignment - I did on my original iron heads but can't remember if I needed them w/ Ebrks. I'll check if it seems relevant to your situation.
I don't see any way you are getting a mechanical pump on a small block w/o modifyng the arm & mounting flange
http://72.22.90.30/phpBB2/viewtopic....pump+edelbrock
http://72.22.90.30/phpBB2/viewtopic....ghlight=ebrock
or, you have to cut out the front of the head & weld a patch in there. I had BTR do this on mine for RobbMc pump & it is pretty deep. This pump is physically larger than the small OE pump but neither one is going in there without mods. $$ probably similar to mod head or convert to electric pump, just depends which route is less distasteful to you.
