Bang for your Buck
Old Sep 13, 2013 | 11:10 AM
my71olds's Avatar
Bang for your Buck
So we rebuilt the original heads on a 350 olds in a 71 Cutlass. As for engine performance what is the next best bang for your buck?
rebuild the carb
ignition improvements
Old Sep 13, 2013 | 11:32 AM
Timing Optimization
Compression (pistons)
Cam
Headers & Dual Exhaust
You won't get anything out of ignition changes for a stock-ish motor, unless you need a tune-up anyway.
Old Sep 13, 2013 | 12:12 PM
my71olds's Avatar
Originally Posted by MDchanic
Timing Optimization
Cam
What is needed for Timing Optimization?
Old Sep 13, 2013 | 12:16 PM
The '71 was set unusually retarded for emissions reasons.
Once you have the rest of your setup the way you want it (or before, if you want to do it twice), you need to use a timing kit (Crane's is good) to modify the advance springs and advance canister to get the timing where it works the best, and determine the best vacuum advance source, manifold or ported.
Old Sep 13, 2013 | 12:48 PM
droptopron's Avatar
delete
Gears - I went from a 2.73 (maybe even a 2.56?) to a 3.23 that is still modest but its a night & day difference. The revs were upped on the highway but nothing that is not tolerable.
Old Sep 14, 2013 | 10:06 PM
64Rocket's Avatar
Should have milled some off the heads, to help compression.
replace timing chain
As what was said "Gears"
Gene
Old Sep 15, 2013 | 02:56 AM
Kennybill's Avatar
If the heads are still off you might want to consider a small camshaft upgrade. Just don't over cam it. A small rv (torque) cam along with tuning/exhaust/gears. Jmo, Ken
71murder
Suspension & Handling
23
Aug 27, 2021 01:31 PM
jag1886
Oct 14, 2013 08:25 PM
rocketrickshaw
Jul 19, 2009 07:31 PM
Jokers69
Mar 28, 2008 10:47 AM
GoldOlds
Jun 14, 2007 10:14 PM
