Oil Fill Tube Removal
Can the oil fill tube be removed on a 72 350 motor without removing anything else?
I tried tapping it back and forth with a rubber mallet and gently using vice grips to try to spin it, but nothing. Is it connected by some other means?
The tube is pressed into a hole in the block. There are no other fasteners. On the other hand, I have never successfully removed an oil fill tube without destroying it or at least severely crushing it.
The oil fill tube is structurally strong enough to be hit (at the top - that gives the best leverage) with more than just a light tap. Side to side and then front to back. In between that, grasp it and try rotating as like stirring a pot - both directions. Trying to spin it with vice grips is just and invitation to crushing it or scratching it up. Sooner than later it will release and come out fairly easy.
NOTE: Don't go crazy with beating the heck out of it though - just uniform hits like putting a wheel cover back on. The vibration from the hits helps break the friction bond between the filler and the block. You can also spray a little penetrating oil or WD at the base to 'help' it along.
That would be the one. It's probably been turned into a new piece of something by now. Dang, I just dropped it off for free at the metal yard cause they were closed when I got there.
I ended up putting an old socket in the very top part of the fill tube, and putting vice grips around that, to prevent from squishing the tube too much.
I got it out, I mean it was a little damaged, but oh well. I painted it, and it looks okay.
Thanks guys.
Thanks guys.
