Oil Fill Tube removal
I read where you could tap the oil fill tube with a rubber mallet (side-to-side) to remove it. Is this the only way or is there a better way? I thought maybe using a rubber strap wrench to twist it back and forth.
Any thoughts?
d1
Any thoughts?
d1
Well, I definitely don't want to destroy it. So, maybe I will leave it be. I was just looking to paint it and figured it would be easier with it removed.
Originally Posted by Jamesbo;
When ya put it back in IMHO it looks better if the ears on the cap are sticking out right to left parrallel with the core support
X2 I put mine back in and realized I had it a little crocked....just had to straighten it out....if you are doing engine work, while the timing cover is off, use a pry bar from inside and it just pops up pretty easy.
I used a mallet and a block of wood, this way the strikes of the mallet didn't mess up the tube. I also used said tube on top to push the new tube in
I replaced my tube on the 330 because the stock tube had a clip in style cap and it was all dented anyway.
I have a cap in the car for the new tube, but yes I agree, I have to see if it's "right"
I just remove the oil tube from my 350. Had the engine in a stand turned upside down, taped it side to side with a mallett then I put a regular hose clamp around the small section and tap on it as I rotated it around. Came right out.
