1972 F85 Cutlass Engine Mount Change
Old Aug 1, 2013 | 06:18 AM
Niels67's Avatar
Hi there,
I found the left engine rubber mount broken and recieved left and right engine mounts new. Question to installe the new ones is if anyone here did the change by slightly jacking the engine with wheels on ground alone or by first jacking the chassis, supporting the engine on the oil pan screws and lowering the chassis in order to remove the bolts of the mounts side after side. The service manuals dont give instrutions to change the mounts safely without removing the engine. Any help or step by step instruction around here somewhere. Many thanks.
Old Aug 1, 2013 | 06:25 AM
rjohnson442's Avatar
Mr. Johnson
Put the car on stands or ramps to give you some working room underneath. Remove the two long bolts and raise the block with a jack from underneath or use a cherry picker from the top. you only need to lift it a couple inches to get in there. easy swap out from there on.
Originally Posted by Niels67
Hi there,
You'll need to lift the car since you have to do this from underneath. Once the car is safely supported, simply jack under the oil pan using a piece of wood between the jack and the pan sump. Be sure the wood is wide enough to put the load into the sides of the pan, not just the bottom. Remove the cross bolt that holds the motor mount to the frame mount, raise the engine, remove the two bolts from the motor mount to the block, and reverse to install the new mount. Be sure you have P/N 2261 motor mounts or equivalent.
Old Aug 1, 2013 | 06:37 AM
musicars's Avatar
I replaced the mounts on our '72 just as described above. Jack stands to support the chassis and a small jack with a large wood block under the pan. Just place the wood block so it pushes flatly against the pan and not on the drain plug. Do one side at a time to keep things lined up and it goes quickly.
Our mounts had worn so much that the fan was lightly hitting the shroud. the new mounts went in easily and there was a big difference in where the engine sat.
Old Aug 1, 2013 | 06:44 AM
Niels67's Avatar
Thanks for the advice, will post how it went.
Old Aug 17, 2013 | 05:32 AM
Niels67's Avatar
Hi, all worked exactly as described above. Except the left hand side was more difficult to remove because of the heat shield that is to be removed together with the mount. Also you are required to work best with two on it while one is giving a helping hand... Thanks for the tips guys, helped a lot.
CutlassS1972
Aug 14, 2014 07:54 PM
Tony72Cutlass'S'
May 14, 2012 06:29 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
1k442
Mar 3, 2010 08:03 AM
