Where would you mount a fire extinguisher on a 1972 Cutlass?
Hello All,
Hope everyone is doing well. I decided that i wanted to buy some cheap insurance for my Cutlass this weekend (fire extinguishers were on sale at my local hardware store).
So i spent 22 dollars and here is a picture. It is a Garrison ABC fire extinguisher. Should be good for my purposes. It comes with the mounting bracket and 3 holes.
Question is: Where would you mount this on your cutlass?
Thanks!
-Tony
Thanks!
-Tony
Cool! Did you screw it down or it's just sitting there.
I do like the idea of having it affixed permanently, i've gotta do a mechanical inspection on the car soon so i'm hoping to have it look as professional as possible.
I grabbed this picture a couple nights ago. I just installed PUI seat covers as well as the carpet. (seat covers are a hell of a PITA)
So wait, did you have one in your bronco? Because I just want me give my car a dying chance of not burning the ground (especially since since I'm the one working on it...)
Mount it where you can easily reach it and remove it from the bracket with one hand while getting the door open with the other. The bottom line is that if the car lights on fire you are the only hope of saving it (or minimizing damage) so mount it where you will be comfortable grabbing it when your adrenaline is causing your vision to go blurry :-). p.s. mine sits between the drivers seat and the floor shifter bracket. Not bolted down (does not move) because I replace occasionally (per expiration date) and bring it in the house to put by the woodstove in the winter.
Toney72 Cutless S , the Bronco 2 went up in flames some years ago .As it turned out I was the victim of a botched engine rebuild . The fuel line was left lose or came lose and sprayed fuel all over the engine bay. I'm not sure I could have gotten it out if I had had the extinguisher in my lap(it was in a box in the back), this was day one after the rebuild....Tedd
PS. I got high blue book for the car.
This is all great info!
Hopefully this thread will also convince readers to buy a fire extinguisher for themselves. After all the hard work we put into these cars, it's a tragedy to see them go.
I really like the idea of putting velcro on the bracket that holds the extinguisher down. Since i'm really not a fan of drilling into my floor (more than i already have to..)
Another mounting location
In my 1971 Cutlass, its mounted on the passenger-side kick pad. There is an existing screw in the kick pad. I set the fire extinguisher in the mount on the floor, then checked where to drill a hole in the mount to match the existing screw hole. I drilled the hole in the mount, then took the screw out of the kick pad then put it back in, passing through the mount. In 15 years, it has never moved and my wife has never complained about it being in the way of her feet. (15 years...maybe its time for a new fire extinguisher...)
Ttt
Maybe, It's time to tell this sad story again
https://classicoldsmobile.com/forums...-you-sick.html
Don't forget to yank the battery cables loose.
I received this p.m. not too long ago
Burnt to a crisp story
I wanted to say thank you for posting that story. Ever since i read it i now keep my battery post on hand tight and i check them every once in a while. But anyway i was cruising to a car show saturday morning in my 62 stepside and my wife was in the 442 behind me. I turned into the bank to get some cash and the dash started smoking real bad. First thing i remember was your story and the first thing i did was slamm on brakes and ran to open head and pull the hot wire off battery. The only damage was some melted wiring for the turn signals and 1 brake light. But if i didn't read your story the truck may not have made it. Hopefully others have read your story and hopefully remeber to take evasive action.
Hello All,
Thanks!
-Tony
Thanks!
-Tony
I feel your pain. I lost a 79 monte carlo in 1984. Now and i have one in every car. In my vert its sitting behind the drivers seat, no bracket. I want to mount it to the tranny hump on the rightside of the 8-track player but dont have a bracket. Its a wall mount type. Its Big, I think they call it a 5 pounder. Those small extinguisher i dont trust to have what it may take to get it out. It also gets tested and recharged every year. I like it out in the open, just in case im not near it and anyone could plannly see it. Nice post by the way, Chris
I almost lost my car to a leaking carb that I think caught fire from the distributor... luckily I had an extinguisher in the trunk and was able to put out the fire... now i carry mine under the seat but I am also looking to mount it somewhere in the back.
There should be a date code right on the label saying the date of manufacturer and when it should be "checked" i dont think they ever go bad. Just re-filled and topped up.
jag1886
Mar 17, 2018 12:12 PM
w-30dreamin
Nov 29, 2010 05:20 AM
