Where would you mount a fire extinguisher on a 1972 Cutlass?
Old January 30th, 2012, 08:54 AM
Tony72Cutlass'S''s Avatar
Hello All,
Hope everyone is doing well. I decided that i wanted to buy some cheap insurance for my Cutlass this weekend (fire extinguishers were on sale at my local hardware store).
So i spent 22 dollars and here is a picture. It is a Garrison ABC fire extinguisher. Should be good for my purposes. It comes with the mounting bracket and 3 holes.
Question is: Where would you mount this on your cutlass?
Thanks!
-Tony
Tony72Cutlass'S' is offline
Old January 30th, 2012, 08:58 AM
Not sure about yours, but I was able to get one right up against the left side of the driver's seat, between the seat and the door, on the floor, in my Chevelle.
MDchanic is offline
Old January 30th, 2012, 09:01 AM
Lady72nRob71's Avatar
Mine is under the left front seat, but not secured. The bracket was left on the unit to keep it from rolling out to the back.
Lady72nRob71 is offline
Old January 30th, 2012, 09:11 AM
Cutlass Lover
cutlassgal's Avatar
Mine is laying in the floorboard of the backseat, behind the drivers seat. Unmounted.
cutlassgal is offline
Old January 30th, 2012, 11:26 AM
Cool! Did you screw it down or it's just sitting there.
I do like the idea of having it affixed permanently, i've gotta do a mechanical inspection on the car soon so i'm hoping to have it look as professional as possible.
Old January 30th, 2012, 11:33 AM
Screwed down.
You might not want to do this if you've got fancy seats, as it does touch the seat, and could damage it through continual rubbing.
MDchanic is offline
Old January 30th, 2012, 11:37 AM
Screwed down.
Ah Okay cool, I'll have to check the fit when i get home.
I grabbed this picture a couple nights ago. I just installed PUI seat covers as well as the carpet. (seat covers are a hell of a PITA)
Old January 30th, 2012, 12:15 PM
Tedd Thompson's Avatar
Mine I'm sorry to say lives it the trunk next to the jack and wrench.I know better too, my old Bronco burnt to the ground for the lack of a fire extinguisher in time...Tedd
Tedd Thompson is offline
Old January 30th, 2012, 12:22 PM
Oh man... Sorry to hear about the car... That's horrible.
So wait, did you have one in your bronco? Because I just want me give my car a dying chance of not burning the ground (especially since since I'm the one working on it...)
Old January 30th, 2012, 01:21 PM
71 cutlass convertible
lshlsh2's Avatar
Mine too.
lshlsh2 is offline
Old January 30th, 2012, 04:00 PM
jackedolds's Avatar
Mount it where you can easily reach it and remove it from the bracket with one hand while getting the door open with the other. The bottom line is that if the car lights on fire you are the only hope of saving it (or minimizing damage) so mount it where you will be comfortable grabbing it when your adrenaline is causing your vision to go blurry :-). p.s. mine sits between the drivers seat and the floor shifter bracket. Not bolted down (does not move) because I replace occasionally (per expiration date) and bring it in the house to put by the woodstove in the winter.
jackedolds is offline
Old January 30th, 2012, 04:28 PM
Toney72 Cutless S , the Bronco 2 went up in flames some years ago .As it turned out I was the victim of a botched engine rebuild . The fuel line was left lose or came lose and sprayed fuel all over the engine bay. I'm not sure I could have gotten it out if I had had the extinguisher in my lap(it was in a box in the back), this was day one after the rebuild....Tedd
PS. I got high blue book for the car.
Old January 31st, 2012, 10:34 AM
hookem horns's Avatar
I've got a short stumpy one that fits perfectly in the glove box. Keep one of those mesh bottle protectors like when you buy wine/booze on it to prevent rattles/scratches.
hookem horns is offline
Old January 31st, 2012, 11:13 AM
frankr442's Avatar
I cut a piece of 5/16 plywood to fit on the floorwell behind the drivers seat and covered it in carpet. Then mounted the bracket to that. Secure, doesn't damage the car and easily moved if I had a fourth passenger.
frankr442 is offline
Old January 31st, 2012, 11:52 AM
Mak
Mak's Avatar
Great idea... I'm gonna do that!
Mak is offline
Old January 31st, 2012, 01:19 PM
WHIPOLDS's Avatar
That is where I keep mine also !
WHIPOLDS is offline
Old January 31st, 2012, 04:50 PM
Shoveling Snow
Hairy Olds's Avatar
Use velcro on the body of the extingusher and stick it to the carpet by the tunnel.
Hairy Olds is online now
Old January 31st, 2012, 04:54 PM
ziff396's Avatar
Why didn't we all do this back in the 60's and 70's? Never heard of fires back then.
Anyways, I have one under the passenger seat laying loose.
ziff396 is offline
Old February 2nd, 2012, 07:39 AM
This is all great info!
Hopefully this thread will also convince readers to buy a fire extinguisher for themselves. After all the hard work we put into these cars, it's a tragedy to see them go.
I really like the idea of putting velcro on the bracket that holds the extinguisher down. Since i'm really not a fan of drilling into my floor (more than i already have to..)
Old February 2nd, 2012, 08:13 AM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
Mount it on the nearest Mustang....
Napoleon Solo is offline
Old April 7th, 2012, 04:26 PM
oldoldss's Avatar
Another mounting location
In my 1971 Cutlass, its mounted on the passenger-side kick pad. There is an existing screw in the kick pad. I set the fire extinguisher in the mount on the floor, then checked where to drill a hole in the mount to match the existing screw hole. I drilled the hole in the mount, then took the screw out of the kick pad then put it back in, passing through the mount. In 15 years, it has never moved and my wife has never complained about it being in the way of her feet. (15 years...maybe its time for a new fire extinguisher...)
oldoldss is offline
Old April 7th, 2012, 05:00 PM
Ttt
Maybe, It's time to tell this sad story again
https://classicoldsmobile.com/forums...-you-sick.html
Don't forget to yank the battery cables loose.
I received this p.m. not too long ago
Burnt to a crisp story
I wanted to say thank you for posting that story. Ever since i read it i now keep my battery post on hand tight and i check them every once in a while. But anyway i was cruising to a car show saturday morning in my 62 stepside and my wife was in the 442 behind me. I turned into the bank to get some cash and the dash started smoking real bad. First thing i remember was your story and the first thing i did was slamm on brakes and ran to open head and pull the hot wire off battery. The only damage was some melted wiring for the turn signals and 1 brake light. But if i didn't read your story the truck may not have made it. Hopefully others have read your story and hopefully remeber to take evasive action.
Jamesbo is online now
Old April 8th, 2012, 09:30 PM
NOVICE car nut
oldsguybry's Avatar
Of course mine is loose on the floor behind the drivers seat !
oldsguybry is offline
Old April 16th, 2012, 12:20 PM
plee3 64Olds's Avatar
I just installed 1 this weekend. I have bucket seats and a B&M Shifter in the floor. I mounted mine between the buckets behind the shifter.
plee3 64Olds is offline
Old April 17th, 2012, 11:18 PM
ah64pilot's Avatar
I mounted mine under the kitchen sink about 10 years ago...I guess I should check it. I'm not prepared for anything but a robbery
ah64pilot is offline
Old April 18th, 2012, 04:30 AM
*ssholes Garage
Seriousfun's Avatar
Originally Posted by Tony72Cutlass'S'
Hello All,
Thanks!
-Tony
On the front passenger side tran hump.
Seriousfun is offline
Old April 18th, 2012, 05:02 AM
*ssholes Garage
Seriousfun's Avatar
I feel your pain. I lost a 79 monte carlo in 1984. Now and i have one in every car. In my vert its sitting behind the drivers seat, no bracket. I want to mount it to the tranny hump on the rightside of the 8-track player but dont have a bracket. Its a wall mount type. Its Big, I think they call it a 5 pounder. Those small extinguisher i dont trust to have what it may take to get it out. It also gets tested and recharged every year. I like it out in the open, just in case im not near it and anyone could plannly see it. Nice post by the way, Chris
Old May 13th, 2012, 09:17 PM
FAZ442's Avatar
I almost lost my car to a leaking carb that I think caught fire from the distributor... luckily I had an extinguisher in the trunk and was able to put out the fire... now i carry mine under the seat but I am also looking to mount it somewhere in the back.
FAZ442 is offline
Old May 13th, 2012, 09:34 PM
1974 DELTA 88
AZ455's Avatar
Mine lays on the driver side floor in front of/under the seat. Probably due for a new one. How long are they supposed to last anyway? It still says charged but it is about 6 years old.
AZ455 is offline
Old May 14th, 2012, 06:29 AM
There should be a date code right on the label saying the date of manufacturer and when it should be "checked" i dont think they ever go bad. Just re-filled and topped up.
jag1886
March 17th, 2018 12:12 PM
dejavu442
August 7th, 2011 10:22 AM
w-30dreamin
November 29th, 2010 05:20 AM
sixty9olds
November 28th, 2010 09:13 AM
1BAD68"S"
November 9th, 2006 04:30 AM
Quick Reply: Where would you mount a fire extinguisher on a 1972 Cutlass?
