Steering pump pulley
Old Jun 15, 2013 | 09:34 AM
Sampson's Avatar
Has anyone ever successfully removed a gm power steering pulley from the shaft without totally destroying it?
Old Jun 15, 2013 | 11:52 AM
Yup.
Is your real question HOW to remove it? Start by telling us if you have a press-on pulley or one held with a nut. The press-on pulleys need a special tool, available at any auto parts store.
Old Jun 15, 2013 | 12:24 PM
Sampson's Avatar
Yup.
Yep it used to be press on. I figured there had to be a tool made,for it. I don't need it now i need a pulley. Thanks for the response Joe. I hope it keeps the next guy from screwing theirs up!
Old Jun 15, 2013 | 01:08 PM
M-14's Avatar
Don't use a 3 jaw puller, you'll bend the pulley.
Rent or buy a p/s puller, some kits have the installer too. A new p/s pump might even have a bolt to install the pulley. Its just a long 3/8 bolt with a nut & washer.
Old Jun 15, 2013 | 04:23 PM
Octania's Avatar
If it had a nut on the shaft, but no lip, you can't use that tool above.
What kind do you have?
With the tool above, an impact tool is advised, and gloved hands.
http://www.getahelmet.com/jeeps/maint/steeringpulley/
Old Jun 15, 2013 | 04:49 PM
Sampson's Avatar
Mine was press on and no nut. The shaft had an Allen wrench slot. I tried the three jaw puller and bent the heck out of the pulley. Lesson learned
Old Jun 15, 2013 | 05:14 PM
I've used a small tie rod end puller with success (at least I think that's what it was - was a couple of years ago).
It had straight jaws, and they fit nicely into the puller groove, and I just gave it a whirl and "POP!"
1971viking
Feb 27, 2011 07:56 AM
MDchanic
Nov 19, 2010 02:54 AM
jtriggy
Suspension & Handling
Apr 30, 2010 08:40 PM
72Ctlss
Jun 23, 2009 03:12 PM
mcutlass1969
Mar 26, 2007 07:09 AM
