Heater Hoses Different Sizes?
1972 Cutlass S, 350 ci motor, TH350 Trans.
Are the heating hoses, supposed to be different diameters? I mean, both hoses going into the heater core. My supply hose running from the water pump to the heater core is 3/4" hose, while the return hose going into the back of the intake is 5/8". Is this right, or should they both be one size or the other, and what size should they be?
Thanks!
Thanks!
Olds (and GM) did this a lot to help prevent assembly line screwups. For example, the two bolts that hold the lower steering shaft to the rag joint are two different sizes. The flare nuts on the brake lines are different sizes. Where parts can be installed incorrectly, design features like this are usually incorporated.
JPC647, not to be a nit-pick, but the 3/4 hose from the water pump is not the supply hose but the return hose and the 5/8 hose from the back of the intake is the supply hose. You had it backwards.
Also, you rolled and burned a w30 in 75? I bet there is an interesting story behind that one!
what happens when the heater core is bypassed ? typically the waterpump is then plumbed to the intake manifold...use the 5/8" ?
also what size is the bypass hose that goes from the front of the intake to the water pump (assuming same 72 350 350 setup)
Texas442
November 27th, 2009 05:01 PM
