Heater Hoses Different Sizes?
Old Jul 28, 2013 | 03:37 PM
jpc647's Avatar
1972 Cutlass S, 350 ci motor, TH350 Trans.
Are the heating hoses, supposed to be different diameters? I mean, both hoses going into the heater core. My supply hose running from the water pump to the heater core is 3/4" hose, while the return hose going into the back of the intake is 5/8". Is this right, or should they both be one size or the other, and what size should they be?
Thanks!
Old Jul 28, 2013 | 04:24 PM
442Harv's Avatar
yes two different sizes.
Old Jul 28, 2013 | 05:00 PM
Octania's Avatar
Helps prevent confusion, right?
Old Jul 29, 2013 | 06:57 AM
Olds (and GM) did this a lot to help prevent assembly line screwups. For example, the two bolts that hold the lower steering shaft to the rag joint are two different sizes. The flare nuts on the brake lines are different sizes. Where parts can be installed incorrectly, design features like this are usually incorporated.
Old Jul 29, 2013 | 08:04 AM
jpc647's Avatar
Okay perfect. Thanks!
Old Jul 29, 2013 | 10:25 AM
1970-W30's Avatar
JPC647, not to be a nit-pick, but the 3/4 hose from the water pump is not the supply hose but the return hose and the 5/8 hose from the back of the intake is the supply hose. You had it backwards.
Old Jul 29, 2013 | 12:01 PM
jpc647's Avatar
Nit-pick welcomed! It'd rather be corrected, than find out the hard way some time in the future. Thank you.
Also, you rolled and burned a w30 in 75? I bet there is an interesting story behind that one!
Old Jul 29, 2013 | 12:33 PM
RetroRanger's Avatar
72 Olds CS
what happens when the heater core is bypassed ? typically the waterpump is then plumbed to the intake manifold...use the 5/8" ?
also what size is the bypass hose that goes from the front of the intake to the water pump (assuming same 72 350 350 setup)
Old Jul 29, 2013 | 06:11 PM
Sampson's Avatar
Thanks for sharing this tidbit Joe. I have often wondered why on all 3 of these items?
Old Jul 29, 2013 | 06:59 PM
I've never been too concerned with it and have used 3/4 on both with no problems.
Tom442
Jan 23, 2014 07:22 PM
Del70
Oct 8, 2010 09:21 AM
mmurphy77
Jun 2, 2010 07:43 AM
Texas442
Nov 27, 2009 05:01 PM
65cutty
Jun 12, 2009 06:45 AM
