What kind of performance to expect?
Old June 14th, 2013, 09:58 PM
350RocketSBO's Avatar
I just had my 350 Rocket rebuild for my 1972 Cutlass Supreme and I'm wondering what kind of performance should I expect?
The car has:
Edelbrock Performer Intake
Lunati Voodoo 262 Cam
Holley Street Avenger 770
#7a heads
Compression I believe was 9:1
Bored over .030
Hooker Long Headers
2.5 inch exhaust all the way through
Spintech Super 9000 Mufflers
Eaton Posi
350RocketSBO is offline
Old June 15th, 2013, 05:15 AM
captjim's Avatar
Around 300 crank HP, 240 at the wheels, should run low 14s, depending on gear, converter, and traction. That carb is a tad big.
captjim is offline
Old June 15th, 2013, 06:22 AM
I thought the carb was a little big as well as I originally had a 650 edelbrock but the guy at the shop that rebuilt my motor insisted that I needed atleast a 750 because of something with the way the intake is made?? Beats me...I started the car for the first time this morning and I'm excited! Can't drive it yet until I put some brakes on that bad boy but I'm ready to see what I have!
Old June 15th, 2013, 06:25 AM
captjim's Avatar
These cars came stock with a 750 cfm Q-jet, but that can be misleading. It should be fine as long as it is dialed in. The car won't be a barn-burner, but should be responsive with decent low rpm torque, and most importantly, fun to drive. What gear is in it?
captjim is offline
Old June 15th, 2013, 06:31 AM
That's mainly what I was looking for, a responsive car with low end power. It has 3:42 gears in it.
Old June 15th, 2013, 11:21 AM
Chevy budget Olds powered
coppercutlass's Avatar
fwiw I ran 13.89's with a mild 350 in my 72 when it was still in all steel form and a gutted interior. It was a 73 350 freshened up and 72 heads with a comp 260h cam edelbrock performer intake 600 cfm carb hei full length headers 9 to 1 compression running only the water pump and alternator. I went to a 3.73 gear and saw no real gain in performance then I added an x pipe and went 13.8's all day. I did a lot of tinkering to get my mild build to run what it did. But it was very very mild.
coppercutlass is offline
Old June 15th, 2013, 11:51 AM
bccan's Avatar
13.9 - 14.1 @ 98-99 w/ a GOOD tune. Should drive well on the street.
bccan is online now
Old June 15th, 2013, 12:13 PM
Sounds like I'll be satisfied...I don't plan on doing a lot of flying in the car but when I want it to get up and go I don't want to be disappointed! Those times you all are mentioning are 1/4 mile times I take it?
Old June 15th, 2013, 08:37 PM
DoubleV's Avatar
Yes. If they were 1/8 mile times you would be sorely dissapointed I assure you!
What cam are you refering to when you say 'Voodoo 262'? Are you refering to the one with 213/219 duration @ .050 lift ( 256/262 advertised )? If so, and you really have 9:1 CR, you have a good tune, and you get decent traction with some drag radials, you could dip into the 13's.
DoubleV is offline
Old June 15th, 2013, 10:35 PM
Yes sir that's the cam and he verified it is 9:1 today...
Old June 16th, 2013, 05:39 AM
380 Racer's Avatar
I don't think the 770 is a mistake, my engines (Olds) always liked bigger carbs than Chebbies. I feel they need a 750 at least.
380 Racer is offline
Old June 16th, 2013, 03:11 PM
captjim's Avatar
Normally I agree, but his build is very mild. And I did say it would be OK.
captjim is offline
Old June 16th, 2013, 03:25 PM
380 Racer's Avatar
OK, I'm sorry.........forgive me.
Aquaholic
February 17th, 2014 07:46 AM
Dead Reckon
December 29th, 2013 02:24 PM
Finn5033
October 10th, 2012 03:10 AM
bobb
Brakes/Hydraulic Systems
October 10th, 2010 12:03 PM
IB ATEST
January 27th, 2009 12:32 PM
Quick Reply: What kind of performance to expect?
