Rocker Arm Choices
Rocker Arm Choices
What choices are there for stud mount rockers for Olds 350/455s? What experiences can people share, pros & cons, for the available rockers that are out there? Scorpion, Crane, HS, etc?
I need to replace my existing Comp roller tips, thought I had the fulcums and slots worked out, but those things are whacked. A number of the pushrod cups are even off on them...
Hope this helps.
I prefer the Crower stainless, but dang, I was trying to keep this a somewhat budget build.
Yes, have the 5/16 x 3/8 studs and Comp guide plates ('69 #5 heads, larger valves, mild port work). A couple guide plates needed tweaking on assembly, but no biggie.
I'll take a look at the Ford rollers, see what's available, thanks for the tip.
I have standard height stamped steel Trans-dapt chrome valve covers, do the aluminum body rockers clear? Or will I have to doctor them? Or new covers?
And the Scorpions? Or should I avoid those? I was actually looking at the Cranes. Anyone comments there?
i was blessed with 2 sets of rockers
https://classicoldsmobile.com/forums...ers-1-6-a.html
not sure if you can use this stuff
make an offer if prices seem unfair
thanks
thanks
I've got the Comp polys that came with the roller tips, are those the shorties?
Stanley
Would double or triple rocker cover gaskets............clear Harland Sharp rollers (Stock polylocks) inside stock rocker covers???.
What I am asking is how much more clearance do you need?
joepenoso
joepenoso
ANY STANDARD poly lock will hit the baffled stock valve covers, not the rocker.
How many gaskets you need depends solely on the height of the poly lock.
Not sure if someone has seen the Ramair Restoration website but they have a set of valve cover spacers .375" thick and with two sets of their steel core gaskets you could retain your stock valve covers and have extra room under there for most rockers ,just a thought.http://www.ramairrestoration.com/vco...er-spacer.html
A stock Harland Sharp poly lock roller rockers will need How many rocker cover gaskets to clear the baffles and not have interference
joepenoso
CutlassLegend
Sep 21, 2011 02:56 PM
