350 Water Pump Choices - A/C
Second water pump just started leaking, shaft seal, weeping from the piddle hole. This is a NAPA iron, the one before was a GMB aluminum. Both crapped out within @ 5000 miles.
What options/suggestions do all have for water pumps? I was looking at the FlowKooler one, anyone have experience with them?
Part numbers would be helpful!
What's the impeller look like on that one?
I was crunched for time, and got a NAPA standard iron rebuilt. I will watch belt tension, etc, and see how long this one lasts. Pretty certain I did everything right on the last one, but will double check this go around. Would blow if I had to do it again in 3-6 months.
I will probably grab a FlowKooler one and keep it on the shelf just in case. Not sure if Evans makes one for Olds, but will be looking into that too.
Nor Cal Andy
Mar 29, 2012 07:27 PM
jasoneswan
Jul 2, 2008 02:59 PM
