350 Water Pump Choices - A/C
Old Jun 26, 2013 | 04:45 PM
HWYSTR455's Avatar
Second water pump just started leaking, shaft seal, weeping from the piddle hole. This is a NAPA iron, the one before was a GMB aluminum. Both crapped out within @ 5000 miles.
What options/suggestions do all have for water pumps? I was looking at the FlowKooler one, anyone have experience with them?
Part numbers would be helpful!
Old Jun 27, 2013 | 07:48 AM
HWYSTR455's Avatar
No one? Has anyone recently purchased a water pump?
Old Jun 27, 2013 | 09:53 AM
455man's Avatar
The GMB aluminum I have has been fine. Not a lot of miles on it yet. Never tried Flowkooler.
Old Jun 27, 2013 | 11:54 AM
HWYSTR455's Avatar
I tried both AutoZone and Advance Auto and they don't carry the GMBs anymore.
Old Jun 27, 2013 | 01:04 PM
501Paratrooper's Avatar
I bought a flowkooler but have not put it on yet.
Old Jun 29, 2013 | 09:44 AM
eazy's Avatar
From: Malvern, PA (Hometown) Williamsport, PA (College)
I just bought an eastern industries steel water pump and am about to put it in.
Old Jun 29, 2013 | 09:58 AM
HWYSTR455's Avatar
What's the impeller look like on that one?
I was crunched for time, and got a NAPA standard iron rebuilt. I will watch belt tension, etc, and see how long this one lasts. Pretty certain I did everything right on the last one, but will double check this go around. Would blow if I had to do it again in 3-6 months.
I will probably grab a FlowKooler one and keep it on the shelf just in case. Not sure if Evans makes one for Olds, but will be looking into that too.
Old Jun 30, 2013 | 07:33 AM
eazy's Avatar
the impeller looked real good, but i botched the install and now my power steering won't line up properly
Old Jun 30, 2013 | 07:41 AM
HWYSTR455's Avatar
Huh? Sure you just didn't get the wrong pump?
Nor Cal Andy
Mar 29, 2012 07:27 PM
plee3 64Olds
Apr 2, 2011 06:36 PM
apachemobile
Jan 2, 2010 04:48 PM
72Ctlss
Jun 23, 2009 03:12 PM
jasoneswan
Jul 2, 2008 02:59 PM
