RPM manifold and factory OAI?
Old Dec 5, 2017 | 07:01 PM
71DP's Avatar
Hi Guys,
I am sure this has been a subject before but I cant find the answer... Does the 7111 RPM fit with a factory OAI hood AND air OAI cleaner?
THanks!
Old Dec 5, 2017 | 07:28 PM
Oldcoyote's Avatar
Model? Year? Engine?
Old Dec 5, 2017 | 07:31 PM
71DP's Avatar
Oh yes. 71 Cutlass with 350... factory ram air and air cleaner setup
scottv442's Avatar
Maintained
short answer no.....not in a 70-72
Old Dec 6, 2017 | 06:03 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Basically it is 2" taller, if you can find a way to eliminate 2", then it is possible. Another option is a 1" spacer, either 4 hole or open on your current intake.
Old Dec 6, 2017 | 12:29 PM
bccan's Avatar
I have used RPM & presently have Street Dom on the blue car w/ OAI. It takes a bit of work, trial & error but I did get it to fit. First off I suggest acquiring a standard 4 barrel air cleaner or maybe repop OAI base so you don't risk screwing up a genuine OAI base if that is what you have.
You have to raise the carb flange hole effectively lowering the base in relation to the hood & carb. I did this with some rubber mallet action & some mush/pushing - brace the base on a 6x6 or suitable pedestal & push down on OD (think pushing down a hoop over a barrel) or administering CPR, sort of. Keep checking square, carb clearance @ linkage, acc pump, etc and hood. I can't remember if I had to massage any grooves for carb "protrusions."
Check w/ OAI top (No Foam), IF/once you are in the ballpark you can put some "soft clearance checkers" like putty, playdough, etc to check clearance to hood & foam height. Put a dab of grease on tips so it doesn't stick to hood + it leaves a mark where it touches. My foam seal is appx 1/2 height of BBO foam but lots of variables in this endeavor.
Old Dec 10, 2017 | 10:18 AM
71DP's Avatar
Thanks for the info brian, will try that one once its in.
Old Dec 10, 2017 | 08:26 PM
oldzzy's Avatar
wait.... what....
I will have this problem eventually as well and I was wondering if buying a 2" drop base, then cutting out the bottom of the original air cleaner base, and welding in the 2" drop base would work?
Old Oct 15, 2019 | 09:09 PM
marxjunk's Avatar
something like this..i bought it cheap
..theres a couple if configs for snorkle placement
JohnnyBs68S
Jul 29, 2014 09:17 AM
Takid455
Mar 2, 2014 07:27 PM
wcourt3010
Oct 2, 2012 12:50 PM
steve19
Nov 30, 2008 11:05 AM
