330 crank breather canister
Old Sep 19, 2017 | 05:35 AM
skippy's Avatar
I am working through my 65 Vista and trying to put everything back on the engine as it should be, as opposed to previous owners bodges. Mine has the early closed breather system without a PCV valve. What I want to know is whats inside the breather cap on the passenger side rocker. I have reinstated the small vac pipe to the base of the carb but not sure if the round disc inside is supposed to be loose and move around. Anyone help on this?
Old Sep 19, 2017 | 06:26 AM
edzolz's Avatar
Yes the small disk is supposed to move. The theory being when the engine creates pressure, the disk allows the pressure to be evacuated to outside air. If the engine creats a vacuum, the disk seals off the opening to prevent drawing in outside contaminants.
Old Sep 21, 2017 | 05:00 AM
skippy's Avatar
ivmachine
Jan 28, 2016 06:10 AM
Skydancer
Sep 2, 2014 03:22 PM
Bernhard
Jan 6, 2013 09:27 PM
68Tom
Nov 8, 2010 02:14 PM
jensenracing77
Sep 4, 2009 05:39 PM
