I need a better fan
Old Oct 18, 2017 | 09:08 AM
garage goat2's Avatar
I need a better fan
I have a 1987 Salon with a 355 SBO in it thats built. This engine came out of my wrecked 1985 442.
I had a pickup truck's fan on it at the time yet it was destroyed in the accident.
And I have no records of the part # on file ( this was 10 years ago)
The fan that was destroyed Had very strong suction, yet the stock one I have now is a wuss!
Would anyone have a part # I could check on ?
I might load the car with tools and go to some yards nearby. And see if they have any trucks or vans in them.
Thanks for any help
Old Oct 18, 2017 | 12:29 PM
Electric or mechanical?
Old Oct 18, 2017 | 06:06 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You need either a factory 6 or 7 blade fan with the extra heavy clutch or the fixed 4 blade fan like the factory fan on my 70.
Old Oct 18, 2017 | 06:11 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have dual 9c1 caprice fans. Im running a stout sbo that runs 12.20's i drive it to the track and back and it will idle all day in traffic no issues. Just fwiw. The stock set up worked but this set up frees up hp
Old Oct 19, 2017 | 05:58 AM
I have a new clutch on it yet I need more fan blades
Old Oct 19, 2017 | 06:26 AM
Does your car overheat or is it just that you don't like the fans on it now?
Old Oct 19, 2017 | 07:34 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I seem to remember the Ford Windstar fan is a popular electric fan from the junkyard. I have not used one though.
Old Oct 19, 2017 | 07:43 AM
Yes to both, I can,t run the AC without it going up to 230.
Old Oct 19, 2017 | 07:46 AM
Do you have the fan shroud and upper and lower air dams installed correctly?
Old Oct 19, 2017 | 03:41 PM
CRUZN 66's Avatar
Olds Fever
I have several different 6/7 blade fans from various engines that I have removed over the years... I will try to take a few photos this weekend and post them... Possibly one will look like your old fan that was damaged...
Old Oct 20, 2017 | 07:35 AM
Thanks Do they have more blades than a factory 307 style would have?
Old Oct 20, 2017 | 08:25 AM
brownbomber77's Avatar
If you're going through this trouble once, just get a factory Camaro, Windstar, or newer GM truck fan and shroud. There's so much space after you remove the mechanical fan.
Old Oct 20, 2017 | 03:54 PM
CRUZN 66's Avatar
Olds Fever
They have 6 or 7 blades as I mentioned in my post...
Old Oct 22, 2017 | 05:07 AM
I went out and counted the blades, Yup there is seven of them.
Old Oct 22, 2017 | 03:21 PM
CRUZN 66's Avatar
Olds Fever
Checked my stock and I don't have any 7 blade fans left, mostly all 5-Blades but different styles...
Bee Saint Louis
Apr 13, 2025 08:28 AM
convertible 63
May 9, 2018 06:10 AM
ostie13
Brakes/Hydraulic Systems
17
Jun 29, 2016 03:52 PM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
