403 oil in coolant
403 oil in coolant
I just finished installing a used but good condition 403 in my Studebaker pickup. Prior to installation, I removed the pan and intake to clean out sludge and installed a new oil pump and timing chain. After running it about 50 miles I have oil in the coolant but no coolant in the oil. Some sites seem to suggest the intake gasket (felpro turkey pan) could cause this. Is that possible? If not, do you have any suggestions before I pull the motor apart? Many thanks for your help!
403 oil in coolant
Thanks for the welcome. I have a separate transmission cooler so it is motor oil. I drained the oil and there is absolutely no coolant in the oil. However,when I drained the coolant I found at least a half pint of oil.
The oil is not pressurized around the intake area, but the oil pump puts out 40-50 psi vs the coolant that has a 15 psi cap (maybe). I can't think of where pressurized oil would get into the coolant passages, though. Every time I had any issues, it was as you said with water in the oil.
403 oil in coolant
It does not make good sense that the intake is causing the problem but that is the only part of this original engine that was disturbed since it was in a rusty 98 and not leaking oil into the coolant. Also, my neighbor and I ran a radiator pressure test and it seemed ok both ways (pressurized and running). I must be missing something obvious
Just to confirm, the transmission lines do not go into the radiator at all? Typical setup for aux cooler is Transmission -> Aux Cooler -> Radiator -> return.
I wonder if oil can get around the timing cover.
403 oil in coolant
No separate oil cooler but I did find this tech tip in the Dick Miller Racing parts catalog:
A customer once complained that his intake was leaking oil between the intake and head on both sides near the carburetor (I did find a pool of oil there). For oil to get by the gasket at that spot, one or both surfaces are not flat. Remember a surface that may be warped by heat and the gasket will still seal until disassembled. Then when the parts are reassembled, they may leak unless they are resurfaced.
I do not own a machinists straight edge but with the best steel rule I own, the intake manifold sure seems warped. So until I learn different from a machine shop, that sure seems like my problem.
Thanks to all who responded!
