Problem after problem.
Old September 10th, 2017, 01:08 PM
330jetstar's Avatar
I believe this part is necessary for the transmission to function properly but it won't fit with my new intake carb setup.
330jetstar is offline
Old September 10th, 2017, 03:20 PM
Yes, it is. Your switch pitch torque converter is commanded to the high stall speed position both at wide open throttle and at idle. The kickdown switch also activates the converter solenoid at W.O.T., but this switch on the dashpot is how it is activated at idle and low speeds. You need to rig some sort of microswitch to replace this part.
joe_padavano is offline
Old September 10th, 2017, 03:27 PM
330jetstar's Avatar
Ok this sounds over my head. Can I simply relocate or does the linkage push it down.
Old September 10th, 2017, 03:32 PM
Yes you can simply relocate it and the linkage does need to push it down. You may need to modify the mounting bracket to operate the same way it did with the old carb.
oldcutlass is online now
Old September 10th, 2017, 03:44 PM
The linkage needs to push it down enough to close the contacts in the switch at the same throttle opening angles as it did originally.
Old September 11th, 2017, 04:02 PM
330jetstar's Avatar
Ok I checked this out on the original intake and the only time it time does anything is when carb is shut. And even at that it hardly touches it at all.
Old September 11th, 2017, 04:22 PM
The Chassis Service Manual details the proper adjustment procedure for that switch and dashpot. Don't assume it is adjusted correctly at the moment.The fact that the intake is painted a non-original blue tells you it has been apart at some time in the past.
Old September 11th, 2017, 06:37 PM
330jetstar's Avatar
I think it's time I order a manual does anyone sell one book. Instead of multiple manuals.
Old September 12th, 2017, 03:42 AM
The factory manual was a five volume set. Get an original paper factory manual, NOT a reprint or electronic copy. There were no electronic originals, so any reprint or CD is a scan of an original, and detail always gets lost when that is done.
B964
August 12th, 2017 10:09 AM
Arrowstorm
Suspension & Handling
25
July 29th, 2015 05:52 AM
MaxDog
July 26th, 2011 04:28 PM
kandelino
December 20th, 2010 12:54 PM
emarkay
December 8th, 2004 08:23 AM
Quick Reply: Problem after problem.
