Balancer specs
Old Feb 10, 2018 | 09:07 AM
coppercutlass's Avatar
Chevy budget Olds powered
Balancer specs
Guys I'm at a loss. I had my engine balanced with a stock balancer. It looks a bit iffy and would like to replace it. All the stock balancers I see weight in at 8.5. The one ii have weighs in at 10.09 lbs . I think I found the one I need on ebay (used) but it claims its a specific 350 4 speed balancer ( not w31) but unique. Could this be the reason fr the weight difference between the common balancer and the one I have ????
Also if I buy a balancer with adjustable weights could I just match my weight I'm at now and be fine ????
Never been in this situation and trying to avoid re balancing.
Old Feb 10, 2018 | 01:13 PM
cutlassefi's Avatar
You’ll need to find somebody with an arbor that can spin just a balancer. Then you’ll need to balance the new balancer to the same imbalance as the old one. That’s the only way I know to do it.
Old Feb 10, 2018 | 04:26 PM
VC455's Avatar
Barely Registered
By iffy, if you mean the rubber between ring and hub is coming loose, you can have your balancer ring rebonded.
Old Feb 10, 2018 | 04:51 PM
It hasn't spun. The ring looks like it move back a little bit on the hub slightly like the shop possibly dropped it or it was hammered at one point. Either way I found the correct 4 speed balancer on ebay for 70. Hope its good if not then I will have one rebonded and have an extra.
orange442
Oct 8, 2010 08:37 AM
Oldsfan
Apr 23, 2007 09:22 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
