Rear Main Seal - Blue Devil Sealer
Old Feb 5, 2018 | 05:08 PM
sschevellecutlass_Bob's Avatar
Need to replace rear main seal. saw Blue Devil Rear Main Sealer (magic liquid). Anyone ever use it? Is it worth a try?
https://gobdp.com/blog/rear-main-seal-leak-cost-repair/
Old Feb 5, 2018 | 07:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If it is leaking bad enough that it has to be changed, give it shot. I personally have had more Transmission leakage issues of multiple makes, giving sealers in them a shot since I already changed the critical seals.
Old Feb 7, 2018 | 07:35 PM
Purchased some Blue Devil Rear Main Sealer....... will report how it works.
Old Feb 8, 2018 | 05:11 AM
Surprisinngly it's rated decently on Amazon. Keep us posted.
Amazon Amazon
Old Apr 12, 2018 | 11:59 PM
ScottC's Avatar
Did you try it out? Curious if it worked or not.
Old Apr 13, 2018 | 06:06 AM
BillK's Avatar
Bob,
Most of those magic chemicals are just a strong solvent that softens and swells rubber seals. If your Olds engine still has the original rope seal I cannot imagine it doing any good. But you never know
Old Apr 13, 2018 | 07:10 PM
I did try it.... an nope..... didn't work. Not even a little. I decided to pull the engine and fix it the old fashioned way.
Old Apr 14, 2018 | 10:04 PM
ScottC's Avatar
Thanks for the response. Don't have the tools to pull an engine...but...finished my taxes and will hopefully have enough sent back to get it fixed. I just got her last week and found that it was leaking on paperwork the PO had from the day before he sold it to me. Going to a vintage car show a couple miles from my house and going to get a list from the local "old timers" on where they take their vehicles that are honest and trustworthy who know what they're doing.
Old Apr 15, 2018 | 06:44 AM
It is time to upgrade to the Ford 292, pretty sure that is the neoprene rubber seal repackaged fo the SBO or the AMC straight 6 seal. Both are neoprene and are much easier to install than a rope seal, especially removing the old one. The AMC seal is more difficult to install because the ears need cut off and is a tighter fit, I actually mangled one piece because of the tight fit. The 292 seal is super easy to install. The hard part is the time removing the old rope seal.
70rocketpilot
Aug 4, 2018 06:10 AM
Seff
Non-Olds Engines
Nov 10, 2015 05:17 AM
The_Avaricious88
Body work
Aug 29, 2011 04:29 PM
Redog
Aug 20, 2008 11:48 AM
Redog
Aug 19, 2008 05:03 PM
