1"-20 fuel Inlet fitting what size
Old Dec 12, 2017 | 09:26 AM
Haidda's Avatar
hi guys, i do have a question on the fuel inlet fitting on my Rochester. What is a 1"-20 fitting, what are the measures? I called a few carshops and expert Shops in my area (Europe). No one do have a clue? What is the diameter and how many Threads? Thanks for your help
br Daniel
Old Dec 12, 2017 | 09:46 AM
There is a repair kit for Rochester carb fuel inlets, includes a tap and helicoil. The size of the fuel inlet is 7/8-20 for carbs up to 1971 and 1"-20 for carbs after. Its actually best to send the carb out to a shop for repair to insure its done correctly.
These folks specialize in Rochester carbs:
http://www.sparkyscarbs.com/
Old Dec 12, 2017 | 10:07 AM
Here's a site with parts:
https://quadrajetparts.com/quadrajet...-c-128_27.html
Old Dec 12, 2017 | 11:39 AM
VC455's Avatar
Barely Registered
Originally Posted by Haidda
What is a 1"-20 fitting, what are the measures? What is the diameter and how many Threads?
To answer your question, this is a Unified National Extra-Fine thread (UNEF) with 1 inch nominal OD and 20 threads per inch.
The attached table shows go and no-go dimensions.
File Type: pdf
Old Dec 13, 2017 | 07:28 AM
oddball's Avatar
What's the problem? Are you missing the inlet fitting?
The quadrajet parts site above has a selection of fittings. Note that the normal fittings use an inverted flare, 3/8" tube with a 5/8" nut.
One problem is for each thread size there are two different gasket types - either at the top or the bottom of the threads. You can see in the pictures that some use a smaller clear gasket and some use a larger black gasket. That needs to match the machining on your carb, otherwise there will be a small leak.
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
68Tom
Dec 7, 2010 03:19 PM
Flye
Apr 29, 2009 10:39 AM
68Toro
Apr 4, 2008 06:04 PM
