1987 Olds 307 Vacuum Hose Connections Videos!
Old Sep 7, 2017 | 12:40 AM
kuseetha's Avatar
Smile 1987 Olds 307 Vacuum Hose Connections Videos!
Dear friends,
I video recorded the vacuum hose connections of the '87 Olds 307 as a reference when I was removing them. Thought to share them because someone might find it useful. There was only one hose at the back of the carb which I am not sure. Experts are welcome to comment if there was a mistake in the first place.
This is the link:
http://www.youtube.com/playlist?list...MMPZWDm4mIRjMv
Old Jan 20, 2021 | 11:27 AM
rml05's Avatar
Thanks, could you re-upload it? Would be very helpful.
Old Jan 22, 2021 | 10:13 AM
kuseetha's Avatar
Hi,
I have changed the status from private to unlisted (apologies, that I didn't notice), you may view the playlist through the link now.
I tested it, the link should work.
However, I have noticed a slight difference (I could be wrong too) compared to the vacuum diagram on the sticker pasted on the fan cover.
These video clips were the routing I found on my engine before I took them off. So please double check with the vacuum diagram as well.
You could start with the videos, then you would identify the locations for a start!! Then perhaps double check with the diagram below.
Attached here is the sticker for your reference.
Vacuum hoses 1987 307
HTH
Old Jan 27, 2021 | 11:02 AM
rml05's Avatar
Thanks, yes, some are different. Also due to the model years. Mine is a '85.
Still not clear to me, there are two different hose sizes at the small vacuum ball.
Which one of thme goes to the anti-diesel-solenoid, which one goes to the manifold vacuum source?
oldroyale
May 27, 2011 10:49 PM
1983oldsmobiledelta
Dec 2, 2010 03:37 PM
1983oldsmobiledelta
Sep 10, 2010 12:52 PM
1983oldsmobiledelta
Sep 9, 2010 09:11 PM
harleyrules
Nov 16, 2007 05:27 AM
