engine failure on olds 350
Hi friends,
On my carb converted 76' seville, when i was tuning my carb fuel ratio, engine has block. I was juste able to turn engine with damper puller, only for some degrees.
i have pulled the engine out of car, opened it and the cylinder is damaged.
piston on cylinder #7 is break. this is very strange, timing chain and valves on #7 are not damaged
i have done a video (only in french, sorry, i will post some pictures tomorrow ).
anyone had already have this kind of egine failure ?
Best regards from france.
others pictures of the damaged cylinder :
https://crazymathlefou.000webhostapp...812_214301.jpg
https://crazymathlefou.000webhostapp...812_214328.jpg
https://crazymathlefou.000webhostapp...812_214338.jpg
valves seems ok.
https://crazymathlefou.000webhostapp...812_214431.jpg
valves seems ok.
Was it sitting for a long time? Looks like rust at the bottom of the cylinder? That year 350 was last of the solid main Olds 350's. I can still find untouched 350's from that time in exceptional shape, very durable and reliable for the 70's. I wonder if something fell in the cylinder or your head gasket went, I had a 76 in very good shape mechanically but the coolant was horrible and the shim head gaskets started leaking in the cylinders.
i have finished the complete dissasembly of engine. i have begun a small video but my garage light break down . i'll do another video for showing state of piston, camshaft and crankshaft.
https://www.youtube.com/watch?v=mbwp...ature=youtu.be
https://crazymathlefou.000webhostapp...817_214417.jpg
https://crazymathlefou.000webhostapp...817_214433.jpg
https://crazymathlefou.000webhostapp...817_214443.jpg
costpenn
November 27th, 2015 08:36 AM
Texas442
March 31st, 2011 12:33 PM
phill_ratrodv8
February 25th, 2008 02:31 PM
