355 Build Idea
Old Oct 27, 2017 | 09:00 AM
ajr2820's Avatar
355 Build Idea
Looking to build a street machine. 72 CS
355 SBO
Stock crank and rods
These heads (anyone know anything about them?)
http://www.oldsrocketparts.com/produ...-heads-330350/
Edelbrock Performer RPM intake
Stock Q-Jet
Headers
Looking at @ 10.5:1 (Should be good for 93 octane with the aluminum heads, right?)
Comp 275DEH cam
Anything I am missing? On the right track, or way off base? This is my first build.
Old Oct 27, 2017 | 05:29 PM
cutlassefi's Avatar
What piston?
Cam doesn't have enough lift to make best use of the heads.
You'll need to open up the intake to match the heads.
And imo lose the Qjet, you can get something easier to tune.
Old Oct 27, 2017 | 06:06 PM
coppercutlass's Avatar
Chevy budget Olds powered
my build.
355 with speed pro flat tops, 10 to 1 compression , lunati voodoo cam 522/539 lift 233/242 duration , # 6 heads with just big valves ( no porting), Prw ford full roller rockers, RPM intake, pro gear timing chain, 750 holley DP ,
pretty basic combo street driven and driven to the track and back about 120 miles round trip.
so far 12.20's was shooting for 11's with a 3500 stall. But traction issues became a problem now.
Old Oct 28, 2017 | 06:23 AM
ajr2820's Avatar
What piston?
Pistons would be the SpeedPro flat tops.
If I went with a 1.7:1 rocker on the intake, would that produce sufficient lift or not?
Old Oct 28, 2017 | 06:25 AM
cutlassefi's Avatar
Originally Posted by ajr2820
Pistons would be the SpeedPro flat tops. If possible wait a month for the new Mahle piston.
Maybe, but using the right grind would be better.
Old Oct 28, 2017 | 06:58 AM
ajr2820's Avatar
OR....I could go with this rod
https://www.summitracing.com/parts/s...021a/overview/
and this piston
https://www.summitracing.com/parts/slp-h616cp/overview/
and build a 362. Here are the potential specs.
CYLINDERS 8 BORE 4.125 in. DISPLACEMENT 361.9 cid STROKE 3.385 in. PISTON HEIGHT 9.3175 in. ROD 6.200 in. DECK 9.33 in. COMPRESSION HEIGHT 1.425 in. COMPRESSION RATIO 10.112 :1 HEAD VOLUME (cc) 64 cc DYNAMIC COMPRESSION 8.094 :1 PISTON HEAD VOLUME (cc) 6.400 cc HEAD GASKET BORE 4.155 in. GASKET THICKNESS (COMP.) 0.037 in. QUENCH 0.049 in. PISTON/DECK CLEARANCE 0.012 in. CAM-COMP 275DEH INTAKE DURATION 219 ⁰ @ 0.050" INTAKE ROCKER ARM RATIO 1.7 :1 EXHAUST DURATION 233 ⁰ @ 0.050" EXHAUST ROCKER ARM RATIO 1.6 :1 INTAKE CENTER 105 ⁰ OVERLAP 6 ⁰ LOBE SEPERATION 110 ⁰ EXHAUST CENTER 115 ⁰ INTAKE MAX LIFT 0.505 in. INTAKE LOBE HEIGHT 0.297 in. EXHAUST MAX LIFT 0.507 in. EXHAUST LOBE HEIGHT 0.317 in. INTAKE OPEN @.050 4.5 ⁰BTDC ADV. DURATION INTAKE 275 ⁰ ADV INTAKE CLOSE 63.5 ⁰ABDC ADV. DURATION EXHAUST 277 ⁰ INTAKE CLOSE @.050 34.5 ⁰ABDC ADV. OVERLAP 2 ⁰ EXHAUST OPEN @.050 51.5 ⁰BBDC EXHAUST CLOSE @.050 1.5 ⁰ATDC Note: 5 degree adv.
Old Oct 28, 2017 | 07:10 AM
cutlassefi's Avatar
Yes you could.
But a couple of things;
It's still a crappy piston with a big fat ring pack, just the facts.
Conversely, way overkill on the rod. An I beam with 7/16 bolts would be a better choice. But either way, the small end of the rod will most likely need to be machined on one side as Chevy rods are offset, Olds rods are centered.
And I'd check the heads to make sure they really are 64cc.
Hope this helps.
Old Oct 28, 2017 | 07:17 AM
ajr2820's Avatar
Yes you could.
Hope this helps.
Thanks. Still doing research as you can see. I am more interested at this point in finding more info on the heads. If they are not as advertised, I am back to square one and will be forced to recondition the irons I have.
Old Oct 28, 2017 | 07:51 AM
cutlassefi's Avatar
Not necessarily. Any of the aftermarket heads can be cut to 64cc or even less with no issue. You just have to check them first.
Old Oct 28, 2017 | 02:33 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
https://www.summitracing.com/parts/dms-6020x-4080# Ignore the Canadian dollar amount, our dollar sucks lately.
These are a better piston than the Speedpro. They have the small valve reliefs at 3cc and also available in the 4.065" and 4.100" bore. Mark's piston are more aimed at giving reasonable compression with iron heads. The Mahle piston sounds extremely nice but you need a small dish to take advantage of the better aluminum heads.
Old Oct 28, 2017 | 03:08 PM
cutlassefi's Avatar
Hmmm not entirely true. Again the aluminum heads can be cut all the way down to 50cc. Plus the Mahle will have an even better ring pack, and full coatings.
But it's good to know I'll be able to compete with that price once you include the rings.
Thanks!!
Old Oct 28, 2017 | 03:38 PM
True Mark and very good option but the intake will definitively need cut. I just need to find a spare 350 block, my current one is in good shape.
Old Oct 28, 2017 | 03:58 PM
cutlassefi's Avatar
Cutting the intake is really not a big deal. When it's right it's free hp.
Old Apr 20, 2021 | 08:11 AM
Kennybill's Avatar
Back to your original question, can you spin a 355 above 6,500 rpms. Yes but why would you want to? Stock rods=living on the edge. Iron heads=limited. The only place I could ever see near 6500, with stock rods, would be in the traps. I know everyone has a love affair with rpm's. I'd try lower shift points first, looking for the fastest times. Jmo.
Old Apr 20, 2021 | 10:24 AM
The 350 will make the most power up top. On my current 355 I shift at 6700 and it hits at 7k. I set the light for my reflexes. Albeit my engine will breath up there but I'm still on stock rods and crank. I hit the traps @ 6k but I have a 3.90 I really need a 4.56 I have tried shifting lower like alot of people have said and it's just not the case in my experience.
Old Apr 20, 2021 | 02:18 PM
Yeah, Copper your motor has held together really well and you have the heads and cam to support the higher rpm. Do you even have ARP bolts? Since this thread was started, things have changed with the small chamber Edelbrock heads soon coming out. My bottom end should easily take 7K but the rest will depend on Mark's recipe for 91 octane. I will probably still have to have a clean up mill on the intake to make sure the thicker BBO intake gaskets will fit.
Old Apr 20, 2021 | 04:04 PM
I do have ARP bolts through out and the machine shop that did all the machining does R&D work for dart and other vendors so when I checked everything it was right where everything needed to be.
Old Apr 20, 2021 | 06:41 PM
Quality machining no doubt helps alot.
dynamic63
Apr 19, 2014 09:46 AM
captjim
Mar 18, 2014 07:16 AM
jon69olds
Apr 18, 2013 04:40 PM
MR73OLDS
Apr 13, 2012 05:17 AM
jon69olds
Mar 22, 2012 03:21 AM
