1970 Cutlass Cruiser exhaust.
Old Aug 13, 2018 | 05:09 PM
70indyolds's Avatar
Recently acquired a 1970 Olds Cutlass Cruiser that's been in storage since the late 80s or early 90s. I got it fired up after some tune up parts and found that it is in dire need of a new exhaust. Its a 2 barrel 350 with the weirdest exhaust I've seen in awhile. The passenger manifold looks to have two outlets. The driver side downpipe crosses under the engine and into the passenger side manifold. Can I cap off on of the passenger side outlets and run a true dual system?
J.R.
Old Aug 13, 2018 | 05:20 PM
That is the typical single exhaust setup.
Yes, cap off the crossover port and run duals.
Old Aug 13, 2018 | 05:22 PM
70indyolds's Avatar
thank you for the quick response!
Old Aug 14, 2018 | 06:08 AM
That's how the factory did it. The caps are reproduced. FYI, the pipes from the manifolds to the mufflers will be the same as those for a 4dr Cutlass, which has the same 116" wheelbase. If you want aftermarket 2.5" pipes, I suspect all of them are for the shorter 2dr (112" wheelbase) and will require a 4" section welded in. ElCamino tail pipes will exit right behind the rear wheels. This will help avoid sucking exhaust in the back window if you ever ride with it open.
dalilama
Jun 30, 2016 11:37 AM
yamahondarider
Oct 4, 2013 08:04 PM
ragtop71
May 4, 2011 04:25 PM
cleancutty
Jul 26, 2010 09:59 AM
nukesec1
Dec 12, 2009 11:59 AM
