Craftsman beam type torque wrench on bearing caps?
Old Nov 14, 2018 | 08:23 PM
mother$hip89's Avatar
I have a craftsman beam style torque wrench and bearing caps to install. Since it's all based on metal deflection and reading the pointer I'm not sure how it would be a problem but something feels really wrong about using a tool from Sears that cost under $30 on something important. Has anyone tried this, and am I worrying over nothing?
Old Nov 14, 2018 | 09:10 PM
RandyS's Avatar
Back in the day, that is the only kind we had. Seemed to work out fine back then
Old Nov 14, 2018 | 10:07 PM
Agreed. I used one for the engine rebuild back in 1982 and 36 years later the crank is still where it's supposed to be.
Old Nov 15, 2018 | 03:48 AM
shiftbyear's Avatar
Actually the beam type was the most accurate, scroll down attached article for "ACCURACY", maybe not now with improved technology but the BEAM was king for a long time. The bottom line is that it doesn't matter how accurate the torque wrench is, without proper torque procedures, clean lubricated friction surfaces (threads/bolt heads), your engine could fail. I believe the factory coated fasteners in motor oil before installation. Good luck.
https://www.enginebuildermag.com/200...head-bolt-use/
Old Nov 15, 2018 | 04:37 AM
Destructor's Avatar
I have an old Craftsman beam wrench that was my older brothers’ back when he rebuilt a Z1 motorcycle engine in the basement. I used it many times. The reason I got a click type wrench is because the beam wrench was difficult to read when using in an awkward position.
Old Nov 15, 2018 | 06:10 AM
Run to Rund's Avatar
Use it. As above, the beam type is the most accurate and stays so, unlike the clicker types. I have both but use only the beam type on critical fasteners.
Old Nov 15, 2018 | 07:49 AM
oddball's Avatar
Yup. Side note, clicker wrenches need to be used in a specific method to get repeatable results. It's easy to "power through" the click and get a higher final torque than intended.
Now, using a beam on >100ftlb torque bolts would be interesting, especially by yourself. Bracing the engine and yourself, lining up the pull, keeping it steady, AND squarely reading the gauge. I'd bust a few knuckles for sure.
Old Nov 15, 2018 | 11:59 AM
VinMichael's Avatar
yeah, I had a hard enough time torquing the mains with a clicker for the reasons you mentioned. Though I used studs which require more torque.
Old Nov 16, 2018 | 12:43 PM
D. Yaros's Avatar
Worked fine for me back in 19 and 63 on my 265 V8 Chevy!
Old Nov 18, 2018 | 06:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Interesting, I did not know this. I have both and I have two click type torque wrenches. One read lower than the actual torque, it broke the rear main cap on my 403, thinking around 20 ft/lbs off. I need to put that one in the trunk for an emergency tire changer and make sure I don't use it on a motor again. The look the exact same but the cases are different.
Old Nov 19, 2018 | 06:55 AM
oddball's Avatar
The torque checking tools are getting quite cheap now and are actually quite accurate. I use them to check the torque setting on the wrench when doing anything critical.
e.g.:
http://a.co/d/8Dl1YiG
Transam461
Jun 3, 2019 04:02 PM
cdrod
Jul 28, 2015 12:24 PM
72cuttys
May 31, 2013 07:41 PM
boese1978
Jun 10, 2012 02:21 PM
neoinbiz
Oct 24, 2006 07:42 AM
