Quick Question...455 Main Cap Torque
Old Jun 1, 2019 | 06:39 PM
Transam461's Avatar
I'm building a 455, and am putting the crankshaft in it at this time, and want to verify what the Torque Spec is for the Main Caps. My Chilton manual says ALL V8 torque to 120 ft lb on all caps, but then it has a little "2" Footnote beside it, and it says Main Cap 1-4 torque 80 ft lbs, #5 torque 120 ft lb, so I am confused. What does the Main Caps torque too on a 1972 455?
Thanks!
Old Jun 1, 2019 | 07:11 PM
Run to Rund's Avatar
big blocks, all caps 120. Go in steps and bump #3 so the thrust surfaces are aligned, cap to block. I bump the crank and then use a big screwdriver to hold the crank forward while tightening the bolts.
Old Jun 1, 2019 | 07:14 PM
Transam461's Avatar
Thank You so much for the help, it is much appreciated!
Old Jun 2, 2019 | 04:44 PM
dragline's Avatar
If it's not stated the factory lubed the bolts with motor oil. All friction surfaces (under the bolt head also). Without lube you will get a false torque reading. If you are using ARP lube or other than motor oil the torque value may be different. Many motors have failed due to improper torque procedures.
Old Jun 2, 2019 | 07:16 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Wet torque vs dry....always know the difference.
Old Jun 3, 2019 | 04:02 PM
RetroRanger's Avatar
72 Olds CS
heres a sticky w most BBO and SBO torque specs
https://classicoldsmobile.com/forums...-specs-106813/
mother$hip89
Nov 19, 2018 06:55 AM
cdrod
Jul 28, 2015 12:24 PM
Al2011
Apr 18, 2013 10:49 AM
Al2011
Mar 11, 2013 08:04 PM
neoinbiz
Oct 24, 2006 07:42 AM
