330 exhaust manifold
Hello, I can really use some advice on my 67 44bl cutlass supreme. I currently have single exhaust in need of replacement, and going to go with a dual setup. The clearances to the oil filter housing are so tight, and with the AC compressor there, I'm having trouble getting to these rusted bolts to get the exhaust pipe off the manifold flange. Is it a good idea to remove the oil filter housing to get better clearance? Also, will the pypes DOF10S downpipes work to marry the new dual setup? I think they may be for big blocks since they're advertised for 1965-72 442's. Thanks.
Unfortunately I don’t have the receipt but I do not think there is a difference between big block and small block. Pypes only shows one part number for the downpipes. I also just did an engine swap in my son’s 70 Cutlass - from a 350 to a 455 and the existing exhaust system (not a Pypes) bolted up with no modifications.
