330 exhaust manifold
Old June 4th, 2017, 08:32 AM
67Rocket's Avatar
Looking for a right side exhaust manifold for factory dual exhaust, needs to fit a 66-67 cutlass. Thanks
67Rocket is offline
Old June 4th, 2017, 09:08 AM
TripDeuces's Avatar
Single or dual use the same manifold. It has a block off plate on the bottom for conversion from single to dual.
TripDeuces is offline
Old June 4th, 2017, 09:16 AM
TripDeuces's Avatar
I should have added that I do have this manifold but not sure I want to separate them from my old 330 atm. Hopefully someone will have one for you.
Old June 4th, 2017, 09:17 AM
The Rocket Astronomer
lunaboy's Avatar
i have a few 330 manifolds
lunaboy is offline
Old June 4th, 2017, 05:15 PM
lemoldsnut's Avatar
I also have the manifold
Larry
lemoldsnut@aol.com
lemoldsnut is offline
Old June 5th, 2017, 05:56 AM
67Rocket's Avatar
Thanks, didn't know single and dual manifolds are the same.
67Rocket is offline
Old June 5th, 2017, 09:14 AM
They are the same, what you need to do is buy or fabricate a plate to block the crossover pipe inlet. Most of the resto suppliers carry them.
oldcutlass is online now
Old June 6th, 2017, 03:22 PM
ferndaleflyer's Avatar
I have that in central NC along with the other things you needed---your Wife better?
ferndaleflyer is offline
Old June 12th, 2017, 08:53 AM
67Rocket's Avatar
Yes, thanks. Still using wheelchair.
67Rocket is offline
June 3rd, 2019 11:53 AM
Eightupman
November 13th, 2012 05:16 AM
67cutlass67GS
June 24th, 2012 01:51 PM
Sid
November 12th, 2011 10:27 AM
Col Wickham
December 13th, 2009 06:30 PM
Quick Reply: 330 exhaust manifold
