330 exhaust manifold
Old May 25, 2018 | 05:18 AM
67cutlassguy's Avatar
Hello, I can really use some advice on my 67 44bl cutlass supreme. I currently have single exhaust in need of replacement, and going to go with a dual setup. The clearances to the oil filter housing are so tight, and with the AC compressor there, I'm having trouble getting to these rusted bolts to get the exhaust pipe off the manifold flange. Is it a good idea to remove the oil filter housing to get better clearance? Also, will the pypes DOF10S downpipes work to marry the new dual setup? I think they may be for big blocks since they're advertised for 1965-72 442's. Thanks.
Old May 25, 2018 | 05:53 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Pypes down pipes may need minor mods but others have made them work on 350's.
Old May 25, 2018 | 07:21 AM
These are the ones, im having trouble figuring out if the flange angles will match the small block manifold...i'm thinking they might be for big blocks. What then lol
Old Jun 10, 2018 | 06:08 AM
tkheld's Avatar
I have a Pypes system on my 67 CS Conv with a 330. The downpipes bolt right to stock exhaust manifolds.
Old Jun 10, 2018 | 07:52 AM
do you know the part number for the downpipes they used on your pypes system? The picture of the ones I included is apparently for big block olds
thanks
Old Jun 10, 2018 | 06:07 PM
They bolt to both.
Old Jun 10, 2018 | 06:12 PM
tkheld's Avatar
Unfortunately I don’t have the receipt but I do not think there is a difference between big block and small block. Pypes only shows one part number for the downpipes. I also just did an engine swap in my son’s 70 Cutlass - from a 350 to a 455 and the existing exhaust system (not a Pypes) bolted up with no modifications.
cowboyhedlund
Nov 2, 2018 07:13 AM
67Rocket
Jun 12, 2017 08:53 AM
seanm12
Feb 22, 2015 01:49 AM
dave84
May 3, 2011 11:28 AM
Col Wickham
Dec 13, 2009 06:30 PM
