Olds 350 rebuild let me kno what you see and whst I should replace to get up and run
Old Apr 30, 2018 | 09:14 AM
Cedric Mccormick's Avatar
Block
Bottom of block
Front
Block number
Head
Intake
Old Apr 30, 2018 | 11:04 AM
My442's Avatar
Minimum:
Full Disassembly
Magnaflux block and heads, crank, rods
Full block bake and cleaning
Check: Decks, Bores, crank pins, rod inner diameters - machine as required
Check: Heads for flatness, valve guides, valve job
I always use new pistons, rings, cam bearings, freeze plugs, timing chain, rod/main bearings, gaskets, water pump, fuel pump, oil pump/pick up.
A stock rebuild will run you approximately $4,000....more if you get high performance parts.
Old Apr 30, 2018 | 11:28 AM
Unless you care primarily about gas mileage, I'd lose the SP2P intake and get something else. That manifold design was brought out in the mid-1970s during the dark days of the gas crisis and was never intended to be a performance intake.
Old Apr 30, 2018 | 01:03 PM
What is your budget and expected end result? Is it going back relatively stock, performance, etc?
Old Apr 30, 2018 | 07:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
X2, there are some Olds 260 guys looking for them. That is the only motor where performance improves all around with that intake. I had one on an Olds 350, part throttle was amazing, full throttle sucked as the Qjet was too big for that intake. It worked well with a stock GM TBI which flows maybe 500 cfm and probably the limit for that intake.
Old Apr 30, 2018 | 07:51 PM
coppercutlass's Avatar
Chevy budget Olds powered
what I see and should replace.... well.......... depends on what your goals are. I have had a 307 in my 72 cutlass that was really fun for a cruiser engine with the right parts on a stock long block. The my last engine was a pump gas 355 that powered my 72 cutlass into the low 12's the 307 was just as fun as the 355 on the street. I'm a track rat so I'm not happy until I see numbers ., on the street I'm happy with whatever .
Old Apr 30, 2018 | 08:57 PM
You have the crappiest 350, 77 to 80, still better than a 260 or 307. Make sure the heads are crack free, I believe the exhaust ports crack on those 3A heads. The exhaust port is poor flowing as well. I would do flat top pistons with those heads, would put it just over 9 to 1. Get a Performer or RPM intake and a mild cam, quality timing set, degree the cam, new bearings and any machine work necessary.
61Bat
Wheels and Tires
Jul 25, 2018 06:32 PM
ioldsnut
Wheels and Tires
Oct 5, 2014 09:09 AM
Joffroi
Jun 8, 2014 10:44 AM
BLACKCADDY
May 25, 2011 07:18 AM
mr. matt
Jun 4, 2009 08:18 PM
