Cam lobe/lifter alignment
Old Feb 16, 2019 | 11:38 AM
Matt Joseph's Avatar
Hey everyone ,
want to to get some info on this before I button my motor up. I got the cam and lifters in today. Cam set in nicely. Timing chain abd gear are in. Everything lines up as it should. But I looked in the valley in the center hole where you can see the cam. Looks like the cam lobe and lifter are not centered on each other. Is this normal or is the cam messed up? It’s a new cam and new lifters. Plain flat tappet setup. Cam is a basic RV Melling MT01
Thanks in advance
Old Feb 16, 2019 | 01:42 PM
442Harv's Avatar
Yes that is normal. I think it has something to do with making the lifters spin.
Old Feb 16, 2019 | 01:59 PM
Correct, the offset along with a slight bevel between the lifter/cam lobe causes the lifters to spin n the bores and equalize the wear.
Old Feb 16, 2019 | 02:06 PM
VinMichael's Avatar
That looks like a quality lifter. Maybe a Delphi
Old Feb 16, 2019 | 03:42 PM
Yes, its normal, as stated above it causes the lifter to spin. Follow the manufacturers break in procedure.
Old Feb 16, 2019 | 05:25 PM
66-3X2 442's Avatar
When you say the timing chain lines up,what do you mean by this? Did this cam come with a spec card telling where to install the intake centerline or did you line line the marks up and call it OK? This is the worst mistake made with cam timing. The cam vendor tells you where they want the cam installed and some disregard this. Not picking on you,just asking questions.
Old Feb 16, 2019 | 06:57 PM
I think what the Op is saying is the 2 sprockets were in line with the chain installed.
Old Feb 16, 2019 | 07:01 PM
66-3X2 442's Avatar
I understand what he was saying. I was checking to see how he installed the cam. Did he degree it,put it in just using the timing gear marks? If you just install a cam not checking to see where the cam is,you're just asking for trouble. Just a few degrees off makes the difference in a good running engine or a pig.
Old Feb 16, 2019 | 07:54 PM
VinMichael's Avatar
the dots lined up real good
Old Feb 17, 2019 | 07:59 AM
I agree. Back in the 90s I stuck a new cam in by aligning the dots and the engine didn't have any low end power. When I checked with a degree wheel I found the cam was 8º retarded.
Old Feb 17, 2019 | 08:09 AM
66-3X2 442's Avatar
^^^^^^^^^This is exactly my point. Just because the gear marks align doesn't mean anything. A lot of these parts are made overseas and are junk. We had some Cloyes True Roller gear sets marked wrong and they are top of the line parts. Even if the marks are correct and align correctly doesn't mean the cam is in the engine where the grinder wants it. They give you the specs where they want it installed for a reason.
Old Mar 10, 2019 | 08:20 PM
Fpcopo's Avatar
It’s an RV cam. Those grinds are so mild being off a few degrees won’t make any difference. I’ve degreed in a bunch of cams and never found one off even so much as a degree. Of course the one I don’t check might be the one that is screwed up so I check them anyway.
Old Mar 25, 2019 | 08:01 AM
Just figured I’d touch base. Got motor broken in and after about 2 weeks of timing and carb adjustment got it running well. Thanks for the help
Old Mar 25, 2019 | 08:27 AM
Well done.
VinMichael
Jul 12, 2018 06:49 PM
Cpriester123
Nov 8, 2016 05:46 AM
buzzbomb
Mar 29, 2011 03:15 PM
dman0712
May 14, 2010 07:17 AM
nonhog
Feb 21, 2010 09:21 AM
