roller lifter
Old May 13, 2010 | 08:46 PM
dman0712's Avatar
roller lifter
I have a olds 403 with a hydraulic cam and hydraulic roller lifters. I can see the contact on the cam where the lifters are riding the cam through the valley hole in the block. the rollers seem to be slightly riding towards the edge of the cam. What does this mean? Are they supposed to ride directly in the middle? I am running one of the mondello spacers on the cam to prevent cam walk.
Old May 14, 2010 | 04:50 AM
cutlassefi's Avatar
Spacer or a button? Ideally they should ride in the middle but it would depend on the cam core as well. One way or another I don't think it will really hurt anything.
Old May 14, 2010 | 06:36 AM
dman0712's Avatar
i have the spacer and the button on the end of the cam bolt
Old May 14, 2010 | 07:07 AM
507OLDS's Avatar
Are you running a hyd cam that was made for flat tappet lifters,or are you running a cam that is made for hyd roller lifters? Just thought I would ask.
Old May 14, 2010 | 07:14 AM
dman0712's Avatar
Hydraulic roller lifters. I had this cam custom ground from comp
Old May 14, 2010 | 07:17 AM
dman0712's Avatar
Am I supposed to run the cam spacer between the cam and block and the thrust button becasue thats the setup right now. if i did remove the spacer it would put ther lifter closer to the lobe centerline but not much. I aslo have the spacer on the crank. The parts are from Mondello.
dfire25
May 1, 2015 02:57 PM
jensenracing77
Oct 11, 2014 09:53 PM
e129745
Nov 23, 2012 04:31 AM
Bernhard
Nov 19, 2012 09:14 PM
sethj78
Jul 29, 2009 04:42 PM
