70' 350 specs/tolerances
Old July 13th, 2018, 11:40 AM
Matt Joseph's Avatar
Hey All,
I'm tearing into my 70' 350 and I'm wanting to check the crank journals diameters to see if machining is required. Does anybody have a list of what the crank journal diameters are or what their tolerances are. I have a service manual that shows me all the specs i need but its for 77 and up 350. I know the blocks and items changed from the 76 and prior blocks and I don't want to use those specs if they are wrong for the earlier engines.
Any direction? Thanks in advance
Matt Joseph is offline
Old July 13th, 2018, 12:27 PM
woodie582's Avatar
Matt, as other will say, buy the proper year factory manuals, it will make tearing into it so much less complected.
woodie582 is offline
Old July 13th, 2018, 12:42 PM
I'm fairly sure all SBO have the same crank specs, no matter what year they are.
Fun71 is offline
Old July 13th, 2018, 03:16 PM
cutlassefi's Avatar
Originally Posted by fun71
i'm fairly sure all sbo have the same crank specs, no matter what year they are.
x2.
cutlassefi is offline
Old July 14th, 2018, 05:00 PM
BillK's Avatar
Rod Journal Diameter 2.1238-2.1248"
Main Journal Diameter- 2.4985-2.4995"
BillK is offline
Old August 1st, 2018, 12:15 PM
Found the factory specs, man so much info there. Thanks for heads up
HurstLightning84
July 25th, 2017 05:50 AM
85Cutty442
January 17th, 2016 12:30 PM
halfmoontrail
August 15th, 2013 08:23 AM
Rickman48
November 18th, 2012 07:41 AM
nitrojunkie1029
January 27th, 2012 05:15 PM
Quick Reply: 70' 350 specs/tolerances
