Correct Hone grit
Old Aug 1, 2018 | 05:36 AM
Matt Joseph's Avatar
Correct Hone grit
Hello all,
needing to get a flex hone for the bores on my 70’ 350. Going with cast rings. What is the appropriate hone grit for cast rings? 120, 240, 320?? Also stock bores so the 3.75-4 1/8 size hone is correct? 4.057 on the stock bore I believe.
Thanks!
Old Aug 1, 2018 | 06:14 AM
cutlassefi's Avatar
Plain cast or Moly faced cast?
Old Aug 1, 2018 | 06:20 AM
don71's Avatar
same but different
Look at this site or others.
http://www.enginehones.com/technical.html
https://www.hastingspistonrings.com/...re-refinishing
Looks like 240, but you should check with the manufacturer of the rings you are using. Your flex hone should be only slightly larger than the bore.
Old Aug 1, 2018 | 09:20 AM
Is this what is sometimes called a.....dingleberry?
Old Aug 1, 2018 | 09:24 AM
Haha indeed it is
Old Aug 11, 2018 | 07:01 PM
Thanks for the help guys! I got a 240 and things looking good now
2blu442
Mar 20, 2019 01:34 PM
VinMichael
Mar 19, 2019 11:57 AM
vette442
Jan 5, 2019 08:31 AM
Cuttykidd
Nov 28, 2018 07:03 AM
Fpcopo
Nov 19, 2018 10:34 AM
