CP vs DSS pistons
Old Aug 28, 2018 | 05:51 PM
Fpcopo's Avatar
CP vs DSS pistons
I want to use a 350 piston for my 66 442. The CP pistons look like they might be what I want as they appear to be the newest design. I have also looked at DSS pistons. I can’t find any specs on piston weights. Does anyone know what a standard 350 bore piston would weigh in both brands? Does anyone have experience with either brand? Thanks, much.
Old Aug 29, 2018 | 05:40 AM
cutlassefi's Avatar
Don’t forget the new offering from Mahle Motorsports. They’re made from 4032 material and are available in 4.065, 4.100, and 4.155 bore sizes, have 10cc valve reliefs and all have a better ring pack than both the DSS and CP. Plus the CP is made from 2618 which doesn’t wear quite as well as the 4032 material will. Piston weight with pin and rings is around 675gr for the Mahle, depending on bore size. I sell the Mahle for $659, shipped, with rings.
Old Aug 29, 2018 | 10:34 AM
Fpcopo's Avatar
I’m trying to get the compression up to where the W30 is. The CP has only about 2cc in the valve reliefs. Where can I look at the Mahle specs. I do really like their pistons and the coating is a plus.
im not sure what bore the engine is now so I can’t order them til I get it apart. Thanks.
Old Aug 29, 2018 | 01:29 PM
cutlassefi's Avatar
10cc valve reliefs
.984 pin
1.625 comp distance
1.00, 1.00, 2.00mm ring pack, all steel.
They're not in their catalog yet.
Old Aug 29, 2018 | 03:45 PM
Bernhard's Avatar
Mark
How has the feed back been on the guys running Mahle pistons?
Old Aug 29, 2018 | 03:55 PM
cutlassefi's Avatar
Originally Posted by Bernhard
Mark
Can't speak for others but my project 350 made 416hp and 420tq, with 9.4:1, a TQ40 cam, RPM intake, 750 Slayer and pretty much stock 7a heads. There’s no doubt in my mind that piston is worth an easy 20hp.
Old Aug 31, 2018 | 05:26 PM
aqua67w30's Avatar
CP's are a great piston and had no ring issues in my 461.
Old Aug 31, 2018 | 08:31 PM
Bernard Mondello's Avatar
CP Oldsmobile piston's are awesome and there ring pack 1.5 1.5 3mm is even more AWESOME!!!
For Oldsmobile performance street/strip engine's.
Just MY humble opinion...
Bernard Mondello Racing Enterprises, Corona, California. 951-371-1432
Old Sep 1, 2018 | 06:40 AM
cutlassefi's Avatar
Agreed, CP makes a quality piston, no doubt.
However those are made out of 2618 alloy which won't wear as well as the 4032 material of the Mahle will. Plus the Mahle has an even thinner ring pack for an even larger potential gain in hp and tq.
Just an fyi.
Old Sep 6, 2018 | 09:52 PM
Duh's Avatar
Duh
Dss 400
DSS makes 400 pistons. Not light but a nice piston for the money. 4.06 about 680 grams.
Old Oct 1, 2018 | 02:47 PM
v8al's Avatar
Registered Olds Owner
On the CP and Mahle pistons are these thin ring packs suitable for use on the street or are these more for use in
racing scenarios? My obvious concern is compression/oil ring blow by after several thousand miles of street/highway driving.
Finally, do these rings require a custom ring installation tool?
Old Oct 1, 2018 | 03:48 PM
cutlassefi's Avatar
No, ring tech has come a long way. Take apart any newer engine and they all have thinner rings in them. Do you see today’s older cars smoke like they used to years ago? I don’t.
And all performance pistons come with file fit ring sets. For that yes you’ll need a ring filer.
Old Nov 19, 2018 | 10:34 AM
v8al's Avatar
FYI from the upcoming Mahle catalog:
Mahle Oldsmobile 350 pistons
deadeyejedi
Sep 24, 2019 02:00 PM
FuturamicOldsmobile
Nov 15, 2018 06:39 PM
VinMichael
Jun 6, 2018 10:33 AM
cutlassefi
Jun 4, 2018 09:27 AM
jag1886
Feb 12, 2011 11:02 AM
