Hi,
Looking for ideas on fuel plumbing. Wanted to post a pic of mine and get some others to post pics so I can see what options are out there. For instance, I have a Holley 750 DP with a mechanical fuel pump and no return line. I contemplated adding a pressure regulator (non-bypass as there is no return line) but for starters I wanted to possibly change up my feed line. I currently have the stainless hard double line with the port for the fuel gauge. However the hard line barely clears the AC bracket bolt over the valve cover and it only does now because a portion of the bolt head was ground off with a cutoff wheel. I've seen other setups where it's all braided steel lines and anodized fittings. What is everyone else setup with?
