Clearance issues using 7/16 studs on iron #6 heads
Old May 3, 2018 | 08:17 AM
mr.rocket's Avatar
Is it ok to mill rocker for clearance
Old May 3, 2018 | 02:48 PM
70W-32's Avatar
What lift cam. You can mill the rocker for additional clearance, but shouldnt have to if those are HS Olds rockers.
Old May 4, 2018 | 03:40 AM
mr.rocket's Avatar
565 lift solid flat tappet cam
Old May 4, 2018 | 03:50 AM
mr.rocket's Avatar
solid flat tappet 565 lift I have 5003 HS rockers.
Old May 4, 2018 | 04:37 AM
cutlassefi's Avatar
Yes you can mill the rocker pads.
looks like you’re poly locks are really close to the rocker at max lift. I’d check underneath to make sure the pushrod isn’t hitting the rocker as well
Old May 4, 2018 | 06:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Holy big solid cam, I figured big by how much the spring was compressed. What are the other motor specs?
Old May 4, 2018 | 06:07 AM
mr.rocket's Avatar
so can I mill where the rocker is hitting the poly lock
Old May 4, 2018 | 06:13 AM
mr.rocket's Avatar
355 speedpro flat top pistons, Edelbrock intake, 455 valves, heads and intake ported to match.
Old May 4, 2018 | 06:23 AM
I assume some stall and gearing as well, what car? It should go like hell.
Old May 4, 2018 | 07:22 AM
mr.rocket's Avatar
3.73 gears 3000 stall in a gbody 87 cutlass
Old May 4, 2018 | 10:00 AM
cutlassefi's Avatar
It shouldn’t hit there at all, especially with that amount of lift. Are you sure your geometry is correct?
Old May 4, 2018 | 10:21 AM
mr.rocket's Avatar
yes we checked it twice riding the valve perfect in the middle.
Old May 4, 2018 | 12:32 PM
70W-32's Avatar
somethings not right, shouldnt need to clearance those rockers at that lift
David DeCan
Dec 15, 2016 10:30 AM
NMcCarthy
Nov 16, 2014 08:03 AM
pmathews
Nov 13, 2014 05:25 AM
Chris Wicks
Oct 21, 2012 09:35 AM
