What type of firewall grommet should I be looking for?
Old July 25th, 2018, 07:36 PM
Tiberian Fiend's Avatar
Looks like there's a couple kinds on eBay. I'm looking for the one the wiring harness for the dash goes through. I don't have the car with me to check.
Tiberian Fiend is offline
Old July 26th, 2018, 06:56 AM
Well, which grommet are you exactly looking for? If you are talking about a 1967 Cutlass, the wiring harness for the dash doesn't pass through the firewall. It runs from the fuse box to the dash, period. If you are talking about where the main harness from the fuse box passes through the firewall, there is no grommet. There is the rectangular firewall connector on the backside (ok, technically, the FRONT side) of the fuse box. There should be a foam seal around this connector. The HVAC harness does pass through a firewall grommet.
joe_padavano is offline
Old July 26th, 2018, 11:37 AM
I'm replacing both the dash and rear engine harness and the A/C harness. I thought they all went through the hole the vacuum hoses for the A/C controls went through, but whichever ones I need to replace are the ones I'm referring to.
70sgeek
December 10th, 2018 11:55 PM
OLDS98VERT
November 28th, 2017 11:08 AM
1978 Oldsmobile Omega
August 10th, 2014 07:03 PM
jugdish
June 22nd, 2010 03:29 AM
Maverick
July 30th, 2008 07:51 PM
Quick Reply: What type of firewall grommet should I be looking for?
