OBD1 Scan Tool?
Old Oct 4, 2018 | 09:17 AM
rustbukt307's Avatar
Olds Powered Cadillac
OBD1 Scan Tool?
I'm interested in getting some kind of scan tool to check out my 307's vitals and want some advice on what to get. I want to be able to plug in and see all the engine data like RPMs, TPS readings, Open/Closed loop, etc. The only things I keep finding are OBD2 scan tools, OBD1 code readers or blinkers, or $350 OBD1/2 scanners that I just don't need. Does anyone on here actually use a scan tool for their OBD1 cars and if so what do you use?
Old Oct 4, 2018 | 09:25 AM
Does OBD1 even support the things you want to do?
Old Oct 4, 2018 | 09:48 AM
$350 isn't too expensive. I spent over $200 for an Innova OBD2 scan tool.
Old Oct 4, 2018 | 09:58 AM
ragz442's Avatar
A paper clip, DVOM, tach and dwell meter.
Old Oct 4, 2018 | 11:21 AM
jaunty75's Avatar
OBD1 is not a national standard, so you need a scanner specific to your make of car. Here's a GM OBD1 scanner at Amazon for $20.
https://www.amazon.com/INNOVA-3123-OBD1-Code-Reader/dp/B000EVU8C0/ref=br_lf_m_5bkvna52tdhk6yj_ttl?_encoding=UTF8&s=automotive https://www.amazon.com/INNOVA-3123-OBD1-Code-Reader/dp/B000EVU8C0/ref=br_lf_m_5bkvna52tdhk6yj_ttl?_encoding=UTF8&s=automotive
Old Oct 4, 2018 | 01:50 PM
https://www.amazon.com/INNOVA-3123-O...8&s=automotive
Isn't this just a code reader though? According to the FSM a scan tool can tell the technician engine data.
Old Oct 4, 2018 | 01:53 PM
cherokeepeople's Avatar
obdI was very limited in what it did.as ragz442 said paper clip,thats what we used to get flash codes.
Old Oct 4, 2018 | 02:01 PM
jaunty75's Avatar
Yes, that's a code reader, but I think that's all you're going to find. OBD1 was a crude system by today's standards, and I think Fun71's comment above is right. It's not clear the OBD1 even provides the kind of information you're looking for.
OBD1 is readable without a code reader at all. Depending on the automobile in question, codes can also be read by various combinations of jumping pins with paper clips and counting how many times the check engine light flashes.
Here's a video that shows how to do it for a '91 Pontiac.
Old Oct 4, 2018 | 02:10 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have the Innova OBD 1/2 scan tool. I paid $200 CAD on sale and I am sure I could view some data streaming on my 94 Olds powered 4x4 with factory TBI set up. Of course that ECM was the most advanced OBI 1 TBI ECM.
Old Oct 4, 2018 | 04:48 PM
I found this site on the web:
http://aldlcable.com/
From the first statement on the site, it appears a lot of diagnostic data can be viewed and logged:
There are basically 3 things you need to record diagnostic data from a GM based On Board Diagnostic 1 ( OBD1 ) system on your 1982 - 1995 era car.
1 - A PC computer, preferably a laptop, to collect, log, and analyze the OBD data.
2 - An ALDL cable to interface your PC computer to the ALDL OBDI diagnostic port on your car.
3 - A software program running on your PC to capture the OBD data.
I didn't read through everything but it may have the information you are looking for.
Old Oct 4, 2018 | 06:54 PM
You all need to read the CSM. Yes, the CCC system has a datastream available that lets you read temps, voltages, RPMs, etc. I use an OTC Genisys and I can read TPS voltage, O2 sensor voltage, mixture control solenoid duty cycle, and many other telemetry points.
Old Oct 5, 2018 | 08:54 AM
I have a key-shaped tool that does the same thing as the paper clip so I already know the code, it's a code 21 for the TPS. I need to measure the voltage so I know if it's dead or just out of calibration. I also need to see the engine RPMs so I can set the base idle speeds and set the ILC adjustment for when the A/C is running.
That's great. So a laptop and a cable should do it just fine then. Very helpful, thank you.
Old Oct 5, 2018 | 09:45 AM
Before you spend a bunch of money on an antiquated OBD 1 reader investigate if those tests can be done without it. You should be able to read the sweep of the TPS with a DVOM. That would at least give you minimum and maximum values. Use a tachometer attached to your ignition to measure RPM and set the idle speed. You can also use a dwell meter to measure the duty cycle of the mixture control solenoid on your carb. There really should be no need for an expensive code reader to properly maintain an Olds 307 with CCC carburetor and electronic ignition.
71OldsCut
Sep 24, 2018 08:36 PM
Tedd Thompson
Sep 15, 2016 06:58 PM
83Hurst#1812
Hurst/Olds
May 26, 2015 02:26 PM
HurstLightning84
Aug 16, 2012 04:58 PM
Olds64
Jul 24, 2010 05:57 PM
