Oil slinger issue
Old Nov 4, 2018 | 03:48 PM
Olds455R's Avatar
Oil slinger issue
I have a 307 Olds with a double timing chain on it. I put a 2 piece timing plate on it from Rocket Olds. It scraped the oil slinger due to the oil seal hole sitting so far from the plate and put metal shavings in my oil pan. I know the oil slinger should be used but I want to use the 2 piece plate. All advice is welcomed.
This is the lip of the oil seal
The oil slinger was rubbing up against the chain
Old Nov 4, 2018 | 05:19 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Are the dimensions the same as the stock timing cover? It may be contacting the slinger and causing it to rub against the timing chain. Many us have used various brands of double roller timing chains without rubbing issues using the stock cover.
Old Nov 4, 2018 | 07:20 PM
Olds455R's Avatar
The lip is thicker than the original plate. I'm trying not to go back to the original but may have to.
Old Nov 5, 2018 | 03:59 AM
BillK's Avatar
Maybe call Rocket and see what they say ? Maybe you got one that is made wrong ?
Old Nov 5, 2018 | 07:47 AM
oddball's Avatar
Just call John @ RR. They're good people.
The oil slinger is a good-to-have. It limits the amount of oil that hits the seal, thereby helping reduce any leaks. "slinger" is a hold-over from generations past. In our engines it's a cover - not a slinger.
Looks like RR built one heck of a mount for the seal which looks like it shrouds the seal, so does the same thing.
Ergo no need to use the slinger when using RR's cover.
Old Nov 5, 2018 | 07:51 AM
Not true. Oil on the crank snout will migrate towards the seal via capillary action. When that flow hits the slinger, it gets, er, SLUNG outward, away from the seal. The excessively deep housing on that timing cover does not have that effect. Fix the cover, run the slinger. Frankly, I'm not sure why you need an expensive, thick, machined aluminum timing cover anyway. There are a lot of two piece stamped steel Olds timing covers that work just fine.
Old Nov 5, 2018 | 02:41 PM
Olds455R's Avatar
I will call John tomorrow while I'm at work. Thanks
Old Nov 5, 2018 | 02:44 PM
Olds455R's Avatar
I had an 2 piece from Mondello when they were selling it but years after I got it out my pops garage, the bottom was bent. I like this one cause of the look but I will save it for my 455
Old Nov 8, 2018 | 06:38 AM
oddball's Avatar
....... really? The slinger is smooshed right up against the timing gear which is smooshed right up against the ledge on the crank which has a, what, 1/8" gap from the #1 main? Not a lot of room for oil to be on the crank in that area. And if the oil's on the crank between the slinger and the seal then, well, horse and barn door and all that.
Old Sep 24, 2021 | 09:36 PM
HolleyGreenGiant's Avatar
I know this is really old, but I just ran into the same thing. What did you end up doing?
Ultra Tweaker
May 22, 2019 08:40 PM
Sampson
Mar 27, 2018 10:01 AM
costpenn
May 27, 2015 06:43 PM
TOM1972
Feb 26, 2014 04:44 AM
VinMichael
Jun 4, 2013 02:43 PM
