57-58 to 59-60 Fuel Pump interchangeability?
Old Mar 17, 2019 | 10:07 AM
CholmondeleyWarner's Avatar
Hi all,
The fuel pump on my 1957 super 88 let go recently. It appears to be one from a 1959 or later car with the small diameter (~1/8") vacuum port and a glass bowl. The vacuum wipers have always been a bit slow, even after a rebuilding and cleaning of the wiper transmission, but I assumed it was due to the pump being tired. Would the correct 1957 pump make a difference in the wiper performance? I may go back to the correct pump anyways for originality's sake, but It would be nice to know if I can expect the issue to be fixed.
Old Mar 17, 2019 | 03:19 PM
Charlie Jones's Avatar
Phantom Phixer
The 59's were the first year of electric wipers .
After that the vacuum pump only supplied vacuum to the HVAC system .
Probably why the smaller outlet .
Yes , you should install the correct 1957 pump .
Old Mar 19, 2019 | 12:16 PM
mpolds's Avatar
Actually, even, 1955 - 1957 is the same Fuel Pump, and while 1958 is a one - year ONLY, officially; those two are actually interchangeable..... however, they DO NOT exist any longer by ANY company brand new ----
I can supply you a Fuel Pump Rebuilding Kit ((in the ethanol gas compatible material -- which is CRITICAL now with this ethanol garbage gas we are forced to buy)), but you need your original "CORE"...
1959 - 1960 are V E R Y different fuel pumps ---NOT interchangeable.....
Any questions, call me --- Craig 516 - 485 - 1935..... New York
Old Mar 20, 2019 | 07:42 AM
Tedd Thompson's Avatar
59 - 60 engines are built on the 394 size blocks where as the 57-58 are on the smaller blocks. Though almost the same the deck height is different as is the cam and crank. Probably why the difference in pumps.... Tedd
scharpp
Mar 7, 2015 05:56 AM
Pat McClelland
Tech Editor's Desk
Mar 9, 2013 08:59 AM
christl
Mar 5, 2012 12:52 PM
deaddds
Mar 1, 2012 03:22 AM
sshriber
Mar 22, 2010 06:16 PM
