Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
57 fuel pump
Old Feb 23, 2013 | 04:29 PM
Pat McClelland's Avatar
57 fuel pump
I have run an electric pump on my 57 for 20 years and 2 pumps. They work well but can overpower needle valves if you go inside during warm up. And they{Holley or Carter} were both noisy. What mechanical pump can I use that does not have the stock double acting vacuum pump on top. The vacuum pump was also noisy and took up space where I intend to install an AC compressor. Thanks Pat
Old Mar 9, 2013 | 08:59 AM
Ozzie's Avatar
Lightbulb A modified version
A modified version of the same pump would probably do what you want. With the trend toward electric wipers, some dual action pumps were modified to be single action (fuel only) pumps. This amounted to removing all the vacuum portion of the dual action pump and providing a block off plate and gasket for the top opening of the pump.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
