Installing HEI Dist.
Old Nov 1, 2018 | 08:38 AM
Drsantos's Avatar
Plan on installing HEI in 69 Cutlass does the air cleaner housing need to be modified for clearance?
Old Nov 1, 2018 | 10:37 AM
droptopron's Avatar
delete
If it interferes a 1/2" spacer should do the trick
Old Nov 1, 2018 | 10:50 AM
On an SBO, yes it will hit. Mid-70s cars alternately used an offset air cleaner or a notched air cleaner. As noted, a spacer between the air cleaner housing and carb air horn also fixes the problem.
Old Nov 1, 2018 | 11:10 AM
Drsantos's Avatar
Thanks - easy enough
Old Nov 1, 2018 | 11:40 AM
My '69 4-4-2 has an HEI and full factory air cleaner assembly. No modifications and no clearance issues. If anything, I would guess that there would be more space with the SBO assembly.
Old Nov 1, 2018 | 11:52 AM
You would guess wrong.
The distributor is in exactly the same place relative to the cam on both SBO and BBO, but the taller BBO deck height means that the carb is about an inch higher on the BBO (Toronado intakes excepted). That's why I specifically said that there was a clearance problem on SBOs.
Old Nov 1, 2018 | 12:56 PM
As my dad says, "Well, I be go-to-hell!"
grmchne78
Jan 3, 2017 08:41 AM
jpc647
Apr 30, 2013 11:43 AM
Joeypete
Dec 22, 2009 04:26 PM
Chumley
Jun 18, 2008 06:56 PM
TheRuss
Jun 13, 2007 08:59 AM
