Rear Main Seal
Old Aug 15, 2018 | 09:42 AM
87Brougham's Avatar
Kyle
Rear Main Seal
I saw plenty of people saying that the Ford 460 seal works great, and after cutting it down to metal on the bottom it fits it the block perfectly (except for when it snaps out and hits me in the face). But it’s too long! What do I do?
Last edited by 87Brougham; Aug 15, 2018 at 09:43 AM. Reason: Should I just cut both ends? Or did I get the wrong seal for 1972 Oldsmobile 350
Old Aug 15, 2018 | 09:44 AM
87Brougham's Avatar
Kyle
Or did I get the wrong seal?
Old Aug 15, 2018 | 09:54 AM
442Harv's Avatar
You must have the wrong seal, or not installed all the way. I have never cut any.
Old Aug 15, 2018 | 09:56 AM
87Brougham's Avatar
Kyle
I'm at my wits end, I got a seal from auto zone (specifically for Oldsmobile 350) that didn't work, the crank barely moved with the rope seal, and now I have this seal. So frustrating.
Old Aug 15, 2018 | 10:17 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You need the Ford 292 V8 or AMC 258 seals with the ears trimmed, easy when you see it. The Ford 460 deal is for the BBO, not your 350.
Old Aug 15, 2018 | 10:22 AM
87Brougham's Avatar
Kyle
Ah, Bill Trovato said the 350 used ford 460, the diesel must have a different crank. Anyways... would cutting this do harm even if I make it fit exactly? Just wondering before I go out and buy the 292. I leave for school tomorrow and I just want to get the engine sealed up because I don't want all the work I paid for to rust up while I am gone. Surely you understand.
Old Aug 15, 2018 | 02:53 PM
The BBO uses the 460 seal. The SBO uses the 292 seal. Diesel motors use BBO seals and main bearings.
Old Aug 15, 2018 | 03:17 PM
Does it fit the groove nicely and is just too long? If so, trimming should work.
Old Aug 15, 2018 | 03:19 PM
87Brougham's Avatar
Kyle
yeah I think it fits pretty nice, my neighbor who knows more about cars is coming over later tonight to tell me if it fits fine or is too tight, and he is gonna help me cut it, he told me not to cut it flush, but some other way.
Old Aug 15, 2018 | 04:08 PM
therobski's Avatar
X2 go buy the 292 seal and relax. I cannot tell how many parts I bought for my build that did not fit, even correct part numbers on the label, but that was not in the box! I would not want it to leak after all your hard work...
Old Aug 15, 2018 | 04:11 PM
87Brougham's Avatar
Kyle
yeah, you’re right on both counts. I might as well go do that.
Old Aug 15, 2018 | 05:14 PM
therobski's Avatar
Yes sir!! don't worry about the small stuff on your build. I have a "bad" water pump to change. So far the 64 F-85 is never been on the road for any distance!! Probably off shore rebuild with a weak impeller. AND this is not a "walk in the park repair". I need to pull the electric fans with the radiator etc. But I do Love my Olds...
Old Aug 15, 2018 | 07:23 PM
ragz442's Avatar
The last 2 small blocks I built I got the gasket kits from OPP. The first one was ran from 05 to 2016 (sold car) and never leaked a drop and I beat the **** out of it. My current build doesn't have many miles on it, built in 09 and first started last spring. Just got done hammering on it on Woodward, running great. Surprised a few Chebbies and a couple Furds for a smog era boat. Put the seal in slightly off set in the block and cap and use a small dab of good engine rtv on the corners.
Old Aug 15, 2018 | 07:30 PM
87Brougham's Avatar
Kyle
im trying my best to love mine too, but the expense and these little quirks are really pushing it lol. Neither autozone nor oreillys had it, I’ll try again later.
Old Aug 16, 2018 | 08:43 AM
TripDeuces's Avatar
Isn't the diameter smaller on the 350 journal? If so you probably kinked the seal into something other than a half circle as designed. Get the correct seal instead of trying to modify the wrong one.
Old Aug 16, 2018 | 10:04 AM
^^^THIS!!!
Do not trim or otherwise shave the seal. If it doesn't fit, get a correct one. The correct FelPro seal for an SBO (BS6141) is under $12 at RockAuto.
Old Aug 19, 2018 | 09:05 AM
BillK's Avatar
I used the BS6141 on my Wife's 307 when I did it last year. I swear this is the first time since the car was new that it hasn't dripped some oil
Old Nov 17, 2018 | 10:56 AM
87Brougham's Avatar
Kyle
is this a rubber seal? Really don’t want a rope one.
Old Nov 18, 2018 | 06:24 AM
It is a rubber seal, the 292 Ford seal fits the Olds 260 through 403. https://www.summitracing.com/int/parts/fel-bs6141/m I have used the Supercars Unlimited rubber rear main which no doubt the one above without the straight pieces. I have also used the AMC 6 cylinder seal with the ears cut off. https://www.summitracing.com/parts/f...​​ It is a tighter fit but easy to install with the crank out like your motor.
Old Dec 12, 2018 | 02:53 PM
^^^THIS!!!
I thought I had this figured out (reading the CSM); then, I read this post - now, I have headlights shining in my eyes. I always attempt to do as much research as possible to reduce errors. I read one thing (CSM) then read more to find examples. I finished changing the intake manifold gasket & valve cover gaskets on my 1971 SBO [350cid] Cutlass Supreme convertible. I've elected to R&R the standard volume oil pump [ MELLING M22F], take-up tube/screen [MELLING 22-FS] & oil pump driveshaft [MELLING IS-2F]. I have a minuscule amount of oil seepage from the rear main - since the oil pan will be removed, I am electing to R&R the rear main seal.
This is not an engine-off rear main seal change. I ordered (what I read & researched to be) the correct rear main seal [FEL-PRO BS130442 - Rear Main Seal Set; Rope; Improved design]. But, then I read this post!
QUESTIONS:
(1) I should, instead use the FelPro seal (BS6141) - is this correct? Even though I have found no vendor who lists this as the seal for a SBO (350cid). I'm double-checking my state-of-confusion - please, pardon my ignorance. I'd prefer to trust the knowledge of you guys who have changed these outs - this is why I am double-checking - I may have lost my mind (it's happened);
(2) I have no idea at this point (I have not removed the oil pan, yet - that begins tomorrow), if the rear main seals have ever been replaced on this vehicle - I'm suspecting they have not. My preconceived notion is to expect a rope seal on both the upper & lower seals. This is a minuscule amount of seepage, I don't want to turn it into a leaking faucet. Should I replace both the upper & the lower with the FelPro (BS6141)? My mind is suggesting the possibility of replacing only the lower. Thoughts?
Thanks very much for your time!
EDIT: On edit & doing more research, I have found elsewhere the BS6141 is correct. I'm not sure why two vendors (RockAuto & SummitRacing) both list the FEL-PRO BS130442 for the 1971 Oldsmobile Cutlass 350cid. ARGH!
Old Dec 12, 2018 | 04:38 PM
Is the motor out if the car? If not, getting the rope seal out can be a bitch, installing the rubber rear main is much easier. i had to loosen all the mains and remove the rear cap and bend a round file to tap the old rope seal out.
Old Dec 12, 2018 | 04:41 PM
Old Dec 12, 2018 | 05:09 PM
Tuffnut's Avatar
I just finished doing my 1975 350 with this seal (BS6141), no leaks so far, 700 miles on it.
Jeff
Old Dec 12, 2018 | 05:10 PM
Jeff
Hi Jeff- Engine on or off vehicle?
Old Dec 12, 2018 | 05:12 PM
Tuffnut's Avatar
off the vehicle, complete rebuild
Old Dec 13, 2018 | 04:49 AM
I'm sorry, but you are making this WAAAAY harder than it is.
1) You'll find nothing in the CSM about a neoprene rear main seal because the only factory seal was rope
2) No one lists the BS6141 seal as fitting Olds because it is designed to be a FORD seal for the Y-block. The Oldsmobile community has shown over the years that it also works in the SBO. FelPro does not list it this way. Don't lose any more sleep over that.
3) You must replace both halves of the seal as a set. You cannot use rope on top and rubber on the bottom.
4) Oldsmobile specialty vendors who sell special "Oldsmobile" neoprene seals simply take the FelPro seal, repackage it, and sell it for about ten times what RockAuto sells them for.
Old Dec 13, 2018 | 05:23 AM
1) Not sure why you referenced me as having found anything pertaining to a neoprene rear main seal since I referenced both the CSM & the rear main seal I ordered ( FEL-PRO BS130442 - Rear Main Seal Set; Rope; Improved design] as rope. But that's cool - I was never referencing neoprene.
2) Will not lose any more sleep over it. Very glad I found this post
3) Honestly, I was considering replacing the bottom rear main seal with the same material as the top rear main seal - rope. (Albeit, why I have referenced the FEL-PRO BS130442 - Rear Main Seal Set; Rope; Improved design]. Just a consideration.
4) Again, I was not referencing neoprene anywhere - I ordered the FEL-PRO BS130442 - Rear Main Seal Set; Rope; Improved design.
At the end of the day, I appreciate your input and sage advice. Glad to have found this post. Thank you!
I'll most likely replace both the top & bottom with the BS6141. The top rear main seal rope will most likely be a PITA to remove.
Old Dec 13, 2018 | 08:16 AM
It will be a bitch, if it's the original rope seal to remove. I have used both the Ford 292 seal, the one from Supercars Unlimited, I needed other stuff anyway, an easy fit. The AMC 252 straight 6 rubber rear main seal also works with the "ears" trimmed off. It actually fits tighter, it can be more of a challenge to install with the crank in the motor. Most say offset the seal with a dab of RTV, where the two parts join and where the rear main cap meets the block.
Old Dec 13, 2018 | 08:24 AM
Your previous post made it sound like reading the CSM was causing the confusion about the neoprene seal. Sorry if I read too much into that.
Old Dec 13, 2018 | 10:18 AM
I won't know if it's the original rope seal until I remove the oil pan - current project which begins in ~30 mins. It's seeping a minuscule amount. OK, time to put it on jacks.
Old Dec 13, 2018 | 10:19 AM
  #31
No worries - not an issue. You provide excellent advice & I appreciate your valued input.
67Rocket
Aug 21, 2023 07:50 PM
bigrbandit
Jan 30, 2019 04:55 PM
wabasto
May 23, 2016 08:19 AM
truckerlary
Jun 19, 2015 02:16 AM
VinMichael
Oct 18, 2013 05:26 PM
